Turbohatch
- 2006 Honda Odyssey Touring silver, 2008 M5 GT 5MT pearl white
Have you used that vendor before. Some things make me nervous.
No but its a moot issue since the seller doesn't have this available anymore. Oh well.
LOL! This is why I jumped on it when the seller was out of the US, ships out of Texas too! That Chinese seller was brought up before by the first guy who had this spoiler (also bought from eBay way back so this item comes and goes). Not sure when (if ever) I will get to mount it. I am sitting on a lot of stuff but just don't have the time/desire to do mods anymore.
My back-ordered rims and tires finally arrived. Installed them after we put the kids to bed.
Pink might be a K&N drop in filter?
Turbohatch. Nice rims
Lol...duude, I'm not a car newb!
Finally made the time to do the first (since we've owned her) oil change for the Mazda5, which also meant I got to finally install the spin-on oil filter adapter and start her on synthetic 5W20!!
Hey, I'm surprised someone actually reference my how-to I seriously didn’t think anyone though it was useful or bothers to do this. Btw, you should cut out the notches on the bracket to fit the monster 1L filter. I want to try it just to confirm if it works and, if cheap enough, try the 2L filter too (the larger filters are cheaper)Finally made the time to do the first (since we've owned her) oil change for the Mazda5, which also meant I got to finally install the spin-on oil filter adapter and start her on synthetic 5W20!!
Thanks Silentnoise713 for the write up: (http://www.mazdas247.com/forum/show...rt-from-cartridge-to-canister-filter-–-Mazda5)
I also got to use the 1x6 lumber supplemental ramps I made earlier this week. Lots of clearance and no need to jack up the car (just wheels chocks)! Plus this will fit my project car as well.
Here's the stock filter cartridge housing removed...good riddance.
This is the oil cooler showing the 15mm bolt and gasket in good condition.
And the spin-on filter adapter installed with an OEM filter.
The only thing left was to cut a larger hole in the plastic bell pan so it wouldn't need to be removed for oil changes. Easy work with aviation snips and a Dremel to clean and smooth the edges.
I'm debating on buying a Fumoto valve to make oil changes even faster and save from using crush washers.
Get the fumoto valve! Your hands will not get dirty and oil changes will NOT require any tools! Just a dump pan/bottle and a short hose. It feels really strange the first time b/c I’m so use to the oil change routine and to have all that cut out, I feel like I forgot to do something…
Btw, what springs are you using? I am debating lowering and it would suck if I can’t reuse my rhino ramps. I have a table saw for a DIY ramp but rather not have more clutter taking up space…
Installed Mazdaspeed3 pedals. Swapped clutch and brake cover. Swapped accelerator pedal assembly.
Does the gas pedal assembly make it easier to heel toe? I believe it is one unit and has a higher arc at rest and when brakes are fully depressed. How do you like it? I have Mazdaspeed covers (4) and plan to add some spaces to raise the height of the gas pedal (without having to modify anything). If this works better for you then I hope I can simulate a similar effect. Btw, the cluth pedal cover looks like it would be better suited for brake duty bc it has the curvature for you to toe brake, no? Looks good!
I like pedal proximity. What I don't like is how close the center console is so close to the gas pedal... There's little to no space to the right of the gas pedal makin it hard to drive with boots on (not that I wear boots often).Also, don't you hate how close the gas and brake pedal are to each other?
