Upon disconnecting the switch form the connector, I revealed this. See attached Pic. Does any1 think it could be a problem with the Blower Motor Resistor.
Probably not.
I don't have the wiring diagram in front of me, are the burned up ones on thick wires or thin wires? If the thin ones then maybe a Resistor pack problem, but I still doubt it.
The resistor pack is wired like this:
blower - 4 -R1- 3 - R2 - 2 - R3 - 1
The fan selector switch connects points 1->4 to ground. So even if the resistor pack was completely blown (all resistors open) position 4 should still work and presumably the power connector is rated for that much current. Now if resistors R1/R2/R3 were shorted there would be too much current for the ratings on wires 1,2,3 and the wire itself might get quite hot, and MAYBE that might be enough to melt the housing like you see. But more likely the insulation would have melted off the wires.
Since you say it works on position 1 that tells us that R1/R2/R3 are not open.
Three possibilities come to mind:
1. the connector was slightly loose or installed dirty, and the resulting arcing melted the
housing.
2. Dissimilar metals in the plug and socket, resulting in galvanic corrosion, then increased resistance at the junction and local heating. (This would be incredibly stupid, but look up the history of aluminum wiring in houses...)
3. The blower is partially shorted, resulting in too much current on the higher wires in the normal positions. The lower wires are protected from that extra heating, to some extent, by the blower resistors ( I=V/R).
The most likely resistor pack problem is one of the resistors blowing open. When that happens positions below that do not work (no electrical connection to the blower), and for the positions where the fan blows the compressor will never light (because there is a sense line that must be pulled low attached to line 1, and it will be floating).
