microman777
Would getting a cold air intake for my Mazda MP3 2001 make a difference in engine performance? It is even worth spending $300 for a good one?
they are all basiclly the same i went with injen i think it was 250, just make sure that it has a place for the sensors and you should be good.
minimal gain... more noise than power.So u didn't notice any increase in performance? Quicker response?
grab a drop in filter from K&N or something. much more budget minded with all the gains.
Try cutting a "path" through your front grille that does a better job getting air into the Stock air inlet. Just removing some of the top plastic piece will help more air come in from the front grille. Free mods are win!
It takes a lot to make a N/A MP3 quick. Back in 03-04 My MP3 was modded and i barely edged out a Intake, exhaust EM1(99-00) Civic Si. Kept up with My buddy's 96 GS-R with just an intake, And my Buddy's 89 CRX with a B18B LS swap.
I had the following mods:
Injen RD Cold air intake
Ractive 4-1 header
Custom cat-back exhaust
ACT 6puck clutch
Indigo Lightweight flywheel
SR motorsport cams
SR Motorsport cam gears
150lb weight reduction
Intake Manifold Butterfly removal
Yokohama parada Spec II's.
If your looking for performance out of this car. Your better off going F/I (Forced Induction)!
The MP3's IM already comes without the VTCS butterflies that everyone removes. The VICS butterflies that I assume you removed probably hurt your performance...
Ractive 4-1 header
ACT 6puck clutch
SR motorsport cams
