bryand8930
has anyone had to change their coil packs yet?
Ours is right on the plug and with a TMIC you are keeping heat in between the valve cover and TMIC.
But also getting real cool on the highways.
hot motor != running motor. plus i dont see an intercooler upgrade so i'm assuming you took time to remove the tmic and for it to cool. there is no way you would be able to work on a motor at operating temp. Plastic and metal absorb/dispense heat differently.
also why would you work on a hot motor. that's how you mess up threads.
i changed my plugs on a hot motor and the coil packs were suprisingly cool.
