speedblue88
- 2003 Laser Blue P5
Ok, so I've got a broken sway bar link. How tough is this to fix myself? I know almost nothing about suspension or steering fixes FYI. Thanks.
I had to cut mine out too due to rust, here's a good tip if you have a die grinder or something to cut the nut off, CUT AT AN ANGLE!, and don't cut the whole nut, it relieves the nut of some "pressure" and you can easily take it off with an impact or air rachet.
I'm guessing your refering to the "endlinks"; if so you might want to replace both sides (i.e. LR & RR or FR & FL etc), its really not that hard.
I put all 4 new on mine in about 2 hours or less. The only reason it took so long was because I had to cut mine out. (Rust)
How did you cut the front endlinks off? I got all but the bottom bolt with ball joint removed. Since the bolt faces inward I could not get any tools in there. I think I might just cut the ball joint off and drill them out after that. So if you have any tips for me that would be great. Thanks, Dan
