yep i was thinking that if i used the o2 fix i could delete the cats. i may be wrong but i was thinking that the 2nd cat was for emissions only?
and thank you for tring to help me i'am not tring to be a ass just leaning
i have only worked on v8"s big block chevys
my drag car is a 87 monte carlo ss with 496 big block with a little gas(NOS)
i have not touched the first o2 sensor only the 2nd one
If you removed both cats, you are in a world of hurt. As far as I know, there is no way to avoid a CEL with the first CAT Gone. The second O2 sensor is checking that the CAT is working. You may be able to replace the O2 sensor with a circuit that fakes the ECU into thinking the gas has the right mixture, but no spark plug adapter is going to do it.
