Yes, it does. I had to install an aftermarket hitch beause I needed a 2" square receiver for my travel trailer.Doesn't the OEM one require a notch in the rear bumper?
Separate accessory. I had to buy an OEM hitch too, just to get the wiring harness...((did you buy that as part of the car or seperate as an accessory?
I cant buy the hitch in any form from Mazda. How did you manage to?
I think Canada has a lot fewer lawyers than the US.
When the dealer calls up the part number it wont let them order one unless its a replacement for a factory installed hitch. (They check the VIN)
I plan on purchasing this one from Hidden Hitch. Per their web site site it's a very simple no-drill install--30 minutes.
http://www.hidden-hitch.com/prod.asp?pc=87438
Since I have no plans on towing anything (want it strictly for a bike rack), I have no concerns about wiring, cooling system upgrade, etc.
Here's a video of a CX-9 hitch install--damn simple.
http://www.etrailer.com/tv_hitch_install_mazda_mx-9_2008.aspx
This is what I ordered from etrailer.com from my 2007 CX-9 last May...
#75531 Draw-Tite Class III Round Tube Trailer Hitch Receiver @ $159.95.
#18176 Modulite Protector, Circuit Protected Vehicle Wiring Harness with 4 Pole Trailer Connector @ $49.95
18151 Modulite Installation Wiring Kit @ $9.95
I installed the hitch myself and no drilling is necessary. 6 bolts (3 per side) came with the hitch and it bolted right up to the existing holes in the frame. Then I took the wiring harness to the local U-Haul (on a recommendation from the dealer) and they hardwired it in for me. I think it cost $75 to have them do it. Even though I only plan to tow a canoe trailer or small sailboat out to the lake during the summer (should be less than the 2000 towing capacity w/o the trailering package) I think I may still get a trans cooler installed in the spring.
Does the installed hitch have any affect on removing the spare tire?
I have a brand new original MAZDA CX-9 hitch (Part# 0000-8E-N01), that I don't need anymore. I bought it because the stock "Trailer Hitch Wiring Kit" (Part# 0000-8E-M04) was not immediately available as a standalone item, only in a set with the hitch.
Send me a PM if you are interested. I live in southern Ontario.
