- 2006 Shadow Blue GLI
It's the offical meter now isn't it?
got wake? said:what does the temp and dB's you get have to do with the electrical current flow? having a good ground is for overall efficiency of the system. think of it as bottle necking the power if you don't have a good ground. you want as little resistance for the ground as possible.
and just an FYI, i'm assuming you were using an audio control meter or some other meter other than the new term lab USB meter. unless you have a freshly calibrated mic for each test, you can get upwards of 3-4 dB's difference between readings. some of the extreme competitors i was talking to told me that sometimes they'd get 4-5 dB difference from day to day, since when the mic is used, especially at high dB levels, it will need to be recalibrated for the most accurate and consistant readings. the new term lab is much more accurate and consistant, though. at world finals there was at most a .4 dB difference between competitors personal meters and the ones used for the comp. the difference between audio controls is upwards of 7-8 dB's sometimes.
Poseur said:umm, dude, I hate to say it, but what are you talking about? for one, your "differences" are more or less too small to be measured considering the accuracy of the testing equipment, and two, if you're somuch for the idea of a good ground then why were you so resitant to it before with the "no way in hell" remark?
N1XRR said:
The reason why I tested in a little bit cooler weather was a little more for curiousity...but I was worried about the heat/cold affecting the sub's performance.
AFaceInTheCrowd said:i was considering a mark antony but they are gawdawefull expensive.
