PRICE DROP NEED THIS STUFF SOLD! --> 7/17/12
PRICE DROP AGAIN! ---> 7/11/12
7/7/12 -----> LOWERED PRICES AGAIN!!
6/30/12 ---> SHIPPED ITEMS
also here is my thread on my CP PISTONS & PAUTER RODS
http://**************************/forum/f498/pauter-rods-cp-pistons-72793/
6/29/12 ---> LOWERED PRICES
6/27/12
ADDED
CDHPFP LINE
WATER PUMP
NEW ROD BEARINGS
NEW THRUST WASHER
NEW FLYWHEEL BOLT SET
NEW MAIN BEARINGS
POWER STEERING PULLEY / PUMP
48 STATES ONLY / PAYPAL ONLY
PM ME FOR MY PAYPAL
MY LOCATION IS 54601
*IF MY PRICES ARE TO "REDICULOUS" PM ME AN OFFER BUT DONT LOWBALL ME*
**I work 2nd shift 3pm-11pm I will mostly respond to PM's after work but can reply to some while I am at work**
***I CURRENTLY DONT HAVE A VEHICLE SO ITEMS WILL BE SHIPPED ON THE WEEKEND WITH A CONFIRMATION #***
THINGS THAT ARE SOLD:
TOWHOOK - bazzarino - SHIPPED
RX8 RIMS - mzdspeed3 - SHIPPED
CYLINDER HEAD W/ CAMS - 06SPEED6 - SHIPPED
BRAND NEW OIL PUMP - 06SPEED6 - SHIPPED
NEW OIL PICKUP TUBE - 06SPEED6 - SHIPPED
NEW OIL STRAINER GASKET - 06SPEED6 - SHIPPED
OIL PUMP CHAIN & BOLTS - 06SPEED6 - SHIPPED
ARP HEAD STUDS - 06SPEED6 - SHIPPED
ARP MAIN STUDS - 06SPEED6 - SHIPPED
COMETIC HEAD GASKET - 06SPEED6 - SHIPPED
1 CAMSHAFT - 06SPEED6 - SHIPPED
TRZ RMM - yomyster67 - SHIPPED
TIMING COVER - Death-From-A-Mile - SHIPPED
OIL PAN - Death-From-A-Mile - SHIPPED
THROTTLE BODY - himurax13 - SHIPPED
$15 SOME MOUNT - himurax13 - SHIPPED
CRANK PULLEY - ozzzzz - SHIPPED
N2MB WOT BOX (LAUNCH CONTROLLER) - mca312 - SHIPPED
VALVE COVER - KiddMnKy - SHIPPED
NEW CRANK PULLEY BOLT - bcmurphy87 - SHIPPED
O2 SENSOR - johnnyby05gt - - SHIPPED
TRZ TRANNY MOUNT - dyezun - - SHIPPED
CDHPFP FUEL LINE - - SHIPPED
CLUTCH - - SHIPPED
VALVE COVER TO INTAKE RECIRC HOSE - - SHIPPED
SAMCO HOSE - - SHIPPED
AXLES - - SHIPPED
FUSE BOX COVER - - SHIPPED
AC PRESSURE SENSOR - - SHIPPED
TIMING CHAIN AND GUIDE - - SHIPPED
STILL FOR SALE IS EVERYTHING BELOW THIS SENTENCE!
ANYONE NEED ANYTHING IN PARTICULAR IN THIS PICTURE?
PAUTER RODS - $750 shipped -> 7/17/12 - $700 shipped
CP PISTONS .020" 8.5:1 Compression - $430 shipped -> 7/17/12 - $395 shipped
BARE SHORTBLOCK W/ CRANK GIRDLE & PCV BAFFLE - $900 SHIPPED -> > 7/17/12 - $775 shipped
(the block has been bored and honed to .020" to fit the CP PISTONS, the block has also been resurfaced and machined)
(the crank girdle just needs to be SPEC'd at the machine shop of your choice)
CRANKSHAFT 2.3L MZR DISI - $230 SHIPPED -> > 7/17/12 - $200 shipped
(24K MILES - THE RING GEAR IS OFFSET IF YOU ARE NOT RUNNING THE BALANCE SHAFT ALL YOU DO IS REMOVE IT - CRANK NEEDS TO BE BALANCED BUT THE JOURNALS ARE WITHIN SPEC WHEN I TOOK IT TO THE MACHINE SHOP)
OIL SQUIRTERS - $20 SHIPPED
COIL PACKS - $125 SHIPPED
(35K MILES)
ESC - $325 SHIPPED -> 7/17/12 - $250 shipped
(HAS TWO CPE FLASHES ON IT 35K MILES)
PASSENGER SIDE Y COOLANT HOSE- $20 SHIPPED
(IF ANYONE KNOWS WHAT IT ACTUALLY IS LET ME KNOW)
FLYWHEEL - $175 SHIPPED -> 7/7/12 - $150 shipped
(35K MILES)
OIL FEED LINE - $25 SHIPPED
SOME MOUNT - $12 SHIPPED
OIL CARTRIDGE FILTER HOUSING - $90 SHIPPED -> 7/17/12 - $60 shipped
EGR SOMETHING? - $75 SHIPPED
WATER PUMP - $40 SHIPPED
THERMOSTAT - $45 SHIPPED
BELT TENSIONER - $50 SHIPPED
ALTERNATOR - $95 SHIPPED -> 7/11/12 - $75 shipped
(35K MILES)
TRANSMISSION w/ COBB SHIFTER WEIGHT & LINKAGE - $925 SHIPPED -> 7/17/12 - $850 shipped
(35K MILES - NO GRINDS AND IS PERFECT!)
OIL PICKUP TUBE - $8 SHIPPED
OIL PUMP - $125 SHIPPED -> 7/17/12 - $90 shipped
(24K MILES CAME OFF OF A WORKING MOTOR) THESE COST $260+ brand new
POWER STEERING PULLEY / PUMP - $130 SHIPPED -> 7/17/12 - $100 shipped
BRAND NEW MAIN BEARINGS - $90 SHIPPED
(I PAID $110)
BRAND NEW FLYWHEEL BOLT SET - $40 shipped
BRAND NEW THRUST WASHER - $55 SHIPPED
BRAND NEW ROD BEARINGS - $80 SHIPPED
6/27/12
ADDED
CDHPFP LINE
WATER PUMP
NEW ROD BEARINGS
NEW THRUST WASHER
NEW MAIN BEARINGS
PM ME FOR MY PAYPAL
CLUTCH - - SHIPPED
AXLES - - SHIPPED
(35K MILES)
(35K MILES)
(35K MILES)
(I PAID $110)
