from those two other threads it sounds like that if you use synthetic oil it's supposed to burn, on start up there is smoke, soot on the back bumper
i get no smoke, no soot, I don't use synthetic oil on this car (but my bmw uses synthetic and never had this problem)
My oil was changed about 500km ago, and yes the drain plug is on and tight (no leaks around it or oil filter)
thanks for the threads.
how do i check for blow by? and how do i do a leak down test?
thanks everyone
forgot to mention...i'm using 10w30, car has about 90,000 km, pcv vavle works fine.
no oil in the coolant
my bro has the same car about the same mileage and he hasn't experienced this.
