Amsoil's 0w-30 is their signature oil which gives maximum fuel efficiency and allows you to use their Ea oil filters. What is the negative of using a zero weight oil?
Pennzoil Platinum is made by Shell. Years ago, SOPUS (Shell Oil Production U S) bought Pennzoil and now you are actually using Shell base oils when you buy Pennzoil or Quaker State branded products.
The " Pennzoil wax" rumors have been scotched for some time. Shell's best oil is probably their Rotella line - many a diesel engine, turbocharged or not, has gone a long distance before overhaul on this robust oil. For more info on oil go to www.bobistheoilguy.com . The site is vast and there's nothing but oil heads there. Cheers!
PS: I use PP 5w-30 in my Speed3 because it meets Honda/ Acura HTO-06 specs. At bitog, in the used oil analysis section it shows to hold up well to the Speed3 fuel dilution issues. 17k miles and no problems whatsoever. Also, Redline MTL in the trannie - shifts smooth as silk.
Brad Penn GT1 "Green Oil" if it can hold up to the grave diggers and blown nitrous drag cars its good enough for me mazda. i make a mix of the 0w-30 and 10w30 to get a 5w-30 and it works great
wait...what?? i may be mistaken here but im pretty sure mixing viscosities is a no no. (headshake
I know you could mix something like a straight 30w and a straight 10w lets say and get your 20w but im not sure about mixing like a 5w-30 with a 10w-40?
i couls be wrong tho
Have you checked Bob the oil guy? i agree with maintaining viscosity. but some additives do not like others the way I hear tell?as long as you keep in the same viscosity range its ok as i am combining both 30 weight oil and just changing the additive package. the petrol chemist at the refinery said it was ok
