Remember the fender gaps are not symetrical front and rear. The front wheel openings cut higher into the imaginary centerline of the car viewed from the side. The door side mouldings and rocker panels on your car are still closer to the ground in the front than in the rear, so it still has the proper rake, with the rear slightly higher than the front. MSP/MP3/RB springs advertise a larger drop in back than in front, which I think helps eliminate the "stink bug" ass-high look of the sedan. It is true that the actual genuine MSP blue struts do have a slightly higher spring perch in the rear compared to the Tokiko Blues, but yours is a common setup and I think it looks sweet. My two cents
