jrodhotrod
Contributor
- 2003 Mazda Protege5 (Mine) 2002 Nissan Sentra GXE (Wife's)
I think I have narrowed down the components for my mazdaspeed 6 audio build but I have a question about how many watts RMS I could safely run off the factory alternator.
From what I have been able to read the factory alternator is 110 amps.
Currently I am looking at around 1,400-1,500 watts RMS at the high end (1,000 watts RMS to the Sub at a 2ohm load and 400-500 watts RMS to door speakers at 4 ohm loads)
Is that going to be too much for the factory alternator and do I need to reduce the deman from either the sub amp or multi-channel amp?
The sub is going to be an IDMAX 12" D4 in a sealed enclosure and recommended RMS is 1,000 watts, but I think I'll be okay with something that pushes around 700 if necessary.
Currently I am leaning towards getting the Alpine MRD-F545 and Alpine MRD-M1005 if I go with a 4 channel set-up (active crossover)
MRV-F545 & MRD-M1005
Also still considering the DLS Ultimate series pairing an A6 with something like an A3 if I can afford it, but this is decidedly more expensive.
thoughts?
thoughts?
