BigDaddyMS3
- Mazda, Speed3
During lunch hour at my latest track day at Thunderhill Raceway, Willows, CA. I took advantage of a discount dyno-jet run in one of the garages. Local area temperature was about 82 degrees farenheit. During my sessions, the HP and TQ would decrease between 1 to 2% per run. There was a one minute idle cool down for the turbo between runs. The mechanic suggested running water wetter for two reasons: 1) Don't use coolant at the track, Water Wetter and water only mix should be run in the radiator as coolant on the track is very hazardous, (slippery for my fellow drivers on track if I blow a hose or spring a leak). 2) I should notice cooler engine temps and cylinder head temps with this product and have minimal HP & TQ loss.
Anyone running either water/water wetter only mix or a coolant/water wetter mix on your local tracks with noticeable results?
