Txs Dp
SharkDiver
Speed3
Hey all,I just bought a used TXS DP and I was wondering if I will need new gaskets so I dont get any leaks?It will hook up to my TXS racepipe also.
Shark
i just installed my txs dp/rp today.
i reused the gaskets and have no leaks but my car has 2500 miles on it also.
donut gaskets are fairly robust from my experince not related to ms3's.
good news is it turned my car into beast.fast fast
Did you install a used Dp or was it new with new gaskets?Did you use the stock gasket between the turbo and the DP on the txs dp?Im worried about the gasket between the turbo and the Dp.
Thanks
i reused all the the gaskets.
the one between the turbo and downpipe is copper and i would have not replaced anyway. i say try using the stock ones and if they leak they r easy to replace.
p.s
when you decide to install the dp/rp PB BLASTER is your friend.
spray it on all bolts/o2 sensors before attempting to loosen. amazing stuff!
Ya Im not looking forward to removing the O2 sensors because they are stuck in there,Both of them.I tried to get them out already but I didnt use any PB.Your new Dp didnt come with new gaskets?Or did it and you just didnt use them?Isnt the Dp a pita to install or can you get to the bolts without much of a problem?
Latest posts
