Two questions!
Okay so i have two quickie questions. 1) Found some beautiful Tenzo Type M V2s on craigs. Their size is 19x8.5 5-114.3 and 5-112 +45 offset .3 Will they fit? I'm thinking not without a fender roll. 2) I'm ordering springs soon for the spring. Do H&Rs have any trouble over time in combination with stock struts? Will they last under DD safe driving conditions?? (the struts i mean)
Thanks!
1) You're pushing it, and you'll definitely need a fender roll in the back.
2) There's no evidence that they wear any worse than stock springs at this point. You run the risk when you put them on.
fair enough thank you! What if they were 18'' would a 8.5'' wide fit? i read on here that 8'' wide is the max, that sounds pretty conservative doesn't it?
I run 18X8.5 +38 with 245s and I am on the H&Rs and I needed a heavy roll and pull toget them to stop rubbing. But all worth it in the end, looks legit.
im gonna go 18x8.5 +45 i think. that should require only a mild roll :)
Latest posts
