not everyone feels the need to know all the stupid car lingo donkey...*face palms* butt dyno is that it feels faster.. the car feels faster due to denser air when its colder....you cant trick that...
what if i could wire up the fan to a switch and wire up a temp guage since the one on the dash wouldnt work
wikipedia said:Temperature and pressure
The density of dry air can be calculated using the ideal gas law, expressed as a function of temperature and pressure:
where ρ is the air density, p is absolute pressure, Rspecific is the specific gas constant for dry air, and T is absolute temperature.
The specific gas constant for dry air is 287.058 J/(kgK) in SI units, and 53.35 (ftlbf)/(lbmR) in United States customary and Imperial units.
Therefore:
At IUPAC standard temperature and pressure (0 C and 100 kPa), dry air has a density of 1.2754 kg/m3.
At 20 C and 101.325 kPa, dry air has a density of 1.2041 kg/m3.
At 70 F and 14.696 psi, dry air has a density of 0.074887 lbm/ft3.
The following table illustrates the air density - temperature relationship at 1 atm or 101.325 kPa:
Effect of temperature
Temperature Speed of sound Density of air Acoustic impedance
in C c in ms−1 ρ in kgm−3 Z in Nsm−3
+35 351.96 1.1455 403.2
+30 349.08 1.1644 406.5
+25 346.18 1.1839 409.4
+20 343.26 1.2041 413.3
+15 340.31 1.2250 416.9
+10 337.33 1.2466 420.5
+5 334.33 1.2690 424.3
0 331.30 1.2920 428.0
-5 328.24 1.3163 432.1
-10 325.16 1.3413 436.1
-15 322.04 1.3673 440.3
-20 318.89 1.3943 444.6
-25 315.72 1.4224 449.1
[edit]
Why not? It might not make the car "3x's faster" but it will increase power, which is what this fella is looking for.Fmic wont fix the problem
making your ecm think its cold outside will only make it run worse if not it even runs, TRUST me i do this for a living.....
unplug your ect sensor and iat sensors, bam the car thinks its -40 outside (default value in ecm) and see if your car starts.... or unplug front o2 sensor, bam the car is also in open loop and will also run like complete garbage, btw cars stay in open loop for no longer then a min when cold, usually within 30 sec its in closed loop.
as soon as some one says to "trust" them, thats the last i do!
u sure about that? it'll start just fine with all 3 unplugged. the only 2 sensors that will cause the motor to turn over but not start are the cam and crank posish sensors.
This thread makes me lol. So much bad info.
You simply don't understand what everyone is trying to tell you. Air inlet temps DO NOT equal coolant temps. Keeping the car in open loop won't help.Well you guys really are some good help
Ractive:5914478 said:Want to have a COLD running engine? Just pull out the thermostat and that way the engine will always run cold. Although "NOT" recommended.
