Well since my car is just sitting on jackstands in the garage, I figured I would get to work with all the mods I need to do to get the wheels to fit, one of which is rear camber plates.
Since I have Fortune Auto coilovers, the Ksport rear camber plates that most people run wouldnt be a 100% guaranteed fit (nobody has tried yet)
So Im giving it a go at making my own. Here are some pics of the rear setup and rough draft of what I plan on doing
What I plan on doing. Already have 4 bolts just going to rotate the pillowball 90 degrees and slot the center to accommodate
They were pretty corroded and I had to drill all 4 bolts out to get the pillowball mount separated from the top strut mount
Left/top is just off the car, right is after I soaked it in vinegar over night and scrubbed it down
Basically brand new, just need to get that pillowball to swivel now so I can put it on the car correctly and everything should go to plan. Hoping for -4 to -5 degrees max, if I need that much but I dont think I will. Wheels are going to be 17x9.5 +26
