- San Antonio, Texas
- '15 CX-5 Miata AWD
Led taillights have gone down in price among ebay sellers
No, they're not easily exchangeable. Too many things, sensors, wirings, and setup software need to be added due to the AFS. Not to mention the MSRP price of each LED headlight is the whopping $1,330.55!I have 2014 CX 5 and like the new head lites on the new CX 5 with the LED running lite in the head lite are both years 14-16 the same size head lite and would they exchange ?
Just by looking, the first, DE3022, and the second, DE3175, should work size wise as long as they're 29 ~ 31 mm Festoon LEDs. The third one, DE3175 too, seems too big to fit in. But the best is to consult your seller for fitness.I'm looking to replace my Cargo, Map, Dome and Vanity light bulbs. Looking at SuperBrightLeds, do these "oversize" ones fit?
DE3022 CAN bus LED Bulb - 10 SMD LED Festoon - 31mm
DE3175 LED Bulb - 9 LED Festoon - 30mm
DE3175 LED Bulb - 4 SMD LED Festoon - 30mm
Those oversized 31mm Festoon LEDs from SuperBrightLeds posted above by zlocity look pretty promising by design. You can always pay more for name brand LEDs but they normally are not the latest LED chips. I have cheap eBay LED kit installed more than a year and so far so good! (knock on wood)Can someone recommend some DE3175 for interior dome lights? Ones I had in mind were the Morimoto, Vled, Superbrightleds but I want to see if there are other suggestions.
Mainly looking for brightness and reliability. I tried the ebay kit and they all ended up blinking non-stop when they are on.
Same question, but also - since there are like a million often contradictory posts on this topic - any consensus on good LED replacement bulbs for the interior, primarily overhead/map lights? I'm more interested in good than cheap as I've read too many posts where someone says what a great deal the bulbs were but that they only lasted for six months. In my case, for a 2016.
All interior lights in 2017 CX-5 are the same as 1st-gen's as Mazda didn't make any changes for those. So basically you need five 30/31mm Festoon LEDs for map/dome/cargo lights、two 29mm 2,800K "warm white" Festoon T6 fuse type LEDs for vanity mirror、and two 194/168 type LEDs for license plate. You can always pay more for name brand LEDs but they normally don't use the latest LED chips. I have cheap eBay LED kit installed for 17 months and so far so good. Not all eBay LED kits are the same. You've to check the specs and reputation!Vleds hasnt updates their site for the 2017s yet. Any guides on what to purchase through them to replace all internal lights?
