JDM Sam said:Delete the system all together.
Must not remove VICS...Must not remove VICS...
I don't think you are supposed to do that are you?
Mike R said:If the screws were put in better the system would be damn near perfect.
Dis, the screw never actually fell out, it was really loose though. Might be the reason all these cars sound rough. If the screws never come all the way out, the plates rattle like crazy. My car got rid of the noise I had been bitching about to the dealer for, well, since the car was a couple months old. Even after they replaced the motor for the rod bearing failure.
They had done at least 2 of the cars with the VICS screws problem....
NO DO NOT ATEMPT to delete VICS! VICS is needed. VTCS on the other hand just kills the air flow which I recommend removing.Mazdamia said:Must not remove VICS...Must not remove VICS...
hehe, nah dude, Im not getting excited or anything. Pardon me if I sounded like I was getting loud, definetly wasnt my intention.Mike R said:Chill Dis, I was just stating what happened with mine. I know that most of the time the screws come out and F' up everything.(ie yours) Mine didn't, I noticed the screws were loose after I replaced the intake and was cleaning the original one. In my case, the plates were the rattling that I had heard.
I did the manifold in about 1.5 hours. EGR tube was the worst part.
VICS: Variable Inertia Chamber System (or something) Basically makes the manifold a dual runner, helps top end while keeping the low end power.
VTCS: Variable Tumble Control System: Part of the Ultra Low Emissions system that creates turbulence while the engine temperature is below 149*F To warm the cats up quicker.
SkinnyJoint said:holy s*** so this is getting crazy. someone said an hour someone said 2.5 hours just to get the manifold off...... you must have run into some problems or somthing.
DiS said:hehe, nah dude, Im not getting excited or anything. Pardon me if I sounded like I was getting loud, definetly wasnt my intention.
Question for you bro, so your bolts didnt come off completely? If so, you cought it at the right moment.
VICS: Variable Intake Charge System, which activates at 5250 rpm to force more air inside the head (cylinder combustion chambers)
and you are correct about VTCS
Aricjm15 said:a TSB will be out for the Screws soon
Aricjm15 said:the only reason mazda might decide not to come through would be the cost. the vin break would cover practically all 2.0 powered protege's, and the labor to cost to pay the tech's would be crazy too. if they do come through, and I heard that they should be, i will be swimming in intake manifolds to get through my parts department.
uh, were'nt they ALL made in heroshima?toucci said:"practically all"... but what about the ones made in hiroshima like mine? I thought I was free and clear :'(
unfortunately they won't just check it for you. it takes a lot of time (in shop time ) just for a "check"... if you're almost sure you have the prob then you could just take it in and try to work out a deal with the service manager about if its broken then they fix if not then you pay them for their trouble... (dunno)tttP5 said:so can i just take my car in to a dealer to have them check for the problem? or do i need it to happen and screw up my engine before the dealer does the fix?
i am in no way mechanicallly able enough to remove and engine part and have a look at it myself.
PhreakV said:unfortunately they won't just check it for you. it takes a lot of time (in shop time ) just for a "check"... if you're almost sure you have the prob then you could just take it in and try to work out a deal with the service manager about if its broken then they fix if not then you pay them for their trouble... (dunno)
sorry bro
