Just had the 75k mile service on our Mazda5, and the dealer found a leaky strut up front. They recommend replacing both of the front struts, as well as the rear shocks. With wheel alignment, total estimate is about $1,100. Not sure about the rear shocks, since the car still fares well on the "bounce test," but the handling up front definitely sags a lot more than before. I'm going to take it to an independent garage for a second opinion, but in all likelihood I will at least replace both of the front struts. This is the first major repair that this car has needed.
I've read that the suspension has been a problem area for the Mazda5. Is this a case of the car being too heavy for the suspension design? And are there any replacement struts anyone can recommend that might hold up a little better than the OEM struts (I don't even know who makes the OEM struts)? Thanks.
