feelander said:
i actually have my rcas first going to a crossover with 1:2 output voltage gain and then to my amp. however, i found that i didnt need to increase my gains that much. instead, because the freq response gets better with higher volume, i wanted my normal listening level to be 1/2 volume. so i adjusted the fader to the front speakers until i got a nice front soundstage.
Feelander, I'm curious, what's the max input voltage for your amp?
I ask because the main determining factor for how loud you can get the hacked pre outs from the stock headunit depends on the max input voltage of the amp(s) you are using. Ok, lets create a sceneario that should help explain:
Lets say that you have a 50w/channel amp that has a max input of 8v. In order to get the full 50w/channel going to your speakers, you would need an headunit that can push 8v. Now, many headunits cannot do 8v, so what does an amp manufacturer do? They add a gain level to the amp's channels, which can increase or decrease the incoming voltage of the headunit pre-out. This way, if you have a headunit that can only do 4v max, you can increase the gain level on the amp so you can harness the full 50w/channel. Make sense so far?
However, the amp gain can only amplify the voltage by so much. For instance, if you had a headunit that could only output 1v max, the amp gain may not be able to amplify the signal enough to reach 8v. Lets say at the headunit's full volume and max amp gain level, you can only reach 6v. This means that you could never get the amp to push 50w/channel-remember, the amp needs 8v to reach the full 50w/channel. This is not a universal rule however, as amp manufacturers have different levels of max gain. So, there may be an amp with an 8v input that can amplify a 1v preout signal to 8v.
Now, lets you have an amp that can reach the full 50w/channel at a lower voltage, say a 2v signal. In this case, you could easily apply enough gain to the 1v pre-outs to reach 2v, and push 50w/channel out of the amp. In my case, I have an amp that reaches full power at 2v, so it is not a problem for the hacked pre-outs to match the stock amp level. In Chuyler's case, he may be using an amp with a 4v or 8v max input. So, to match the stock amp level, your best bet is to find an amplifier with a lower input voltage, or just try to get a line amplifier that can add gain. Does this help explain why your volume is low?
Overall, the main problem with the headunit is that I think the volume control chip is programmed for too low of an output. The MCU inside the the headunit controls the volume control chip, and while the volume control chip is capable of outputing 2v RMS at max volume, the MCU keeps the max volume at less than half that. If this scenario is not the case, (which I am pretty sure it is, considering Mazda enabled the loudness feature) than the only other explanation I can think of is that there is an impedance mismatch between the hacked pre-outs and the 10k ohm input of most amplifiers.
This was a much more in depth post than I thought, I think I'll add parts of it to the how to section to how-to for this hack, so people understand the reason behind the quiet volume.
