Hey guys.. I was just thinking it would be great of everyone would post specs of their systems (pics or links too!) and had a review about them. Include details like installation mishaps/hurdles, etc.
Please follow this format : (I'll use my old system as an example)
HeadUnit:
Panasonic CQ-DP875EUC
40watts x 4
3 preouts @ 2V each
Detachable face
Aux-in
Front Speakers:
Cerwin Vega 6002
6.5"
55 Hz-20 kHz
60W (rms)
120W (max)
Rear Speakers:
Cerwin Vega 6002
6.5"
55 Hz-20 kHz
60W (rms)
120W (max)
Subwoofer(s):
Kicker Competitions
2 - 12" subs
300watts RMS each
600watts peak each
8-ohm each (wired to have 4-ohm total)
4-channel Amp:
JBL Decade DA3504
35watts x 4 @ 4-ohm 14.4V
input voltage : 250mV - 4V
2-channel Amp:
JBL Decade DA1002
100watts x 2 @ 4-ohm 14.4V
300watts x 1 bridged (current configuration)
input voltage: 250mV - 4V
Equalizer:
Kenwood KGC-4042A
5-band eq
1/4 DIN size
link: Car pics
Review:
The system as a whole really had poor sound quality. It was mostly a system to "quad" in and that was what I intended on having. The headunit was a pretty good unit, except for the fact that it was pretty sensitive to bumps in the road, causing CDs to skip. The preamp voltage could be better.. as 2V was the most it supplied.
The JBL amps were just "OK." They would get very hot and you could tell the output would decrease as it got hot. I would have preferred to have variable crossovers on the amps, but they only had a switch for a few select frequencies.
The Kickers are just there to add bass.. not high quality.. just decently loud. Of course, there wasn't enough power going to them to get the best out of them, but I'm pretty sure sound quality wouldn't have improved if I added more power.
The Cerwin Vega speakers were not bad. They handle power but really have no low-end. Midbass is adequate.. barely. I would definitely do components in the front insead of coaxials next time.
Overall, I'd give this system a 4 out of 10. It was my first system, and I really had no resources for researching products/designs, etc. I was content with it at the time and that's all that is important I guess! hehe.
HeadUnit:
40watts x 4
3 preouts @ 2V each
Detachable face
Aux-in
Front Speakers:
Cerwin Vega 6002
6.5"
55 Hz-20 kHz
60W (rms)
120W (max)
Rear Speakers:
Cerwin Vega 6002
6.5"
55 Hz-20 kHz
60W (rms)
120W (max)
Subwoofer(s):
Kicker Competitions
2 - 12" subs
300watts RMS each
600watts peak each
4-channel Amp:
JBL Decade DA3504
2-channel Amp:
JBL Decade DA1002
Equalizer:
Kenwood KGC-4042A
5-band eq
1/4 DIN size
link: Car pics
Review:
