- 2001 Mazda MP3
everything is always prospectively speaking, as long as you enjoy driving it.
Not bad for a couple bolt ons. They're about 400 crank normally correct? Did you get a baseline dyno before the mods?
Bah, want handling performance....buy a RX-8.
I didn't gain quite that much over stock as 08-newer Corvettes (LS3s) with NPP exhaust have 438hp at the crank, and put down around 370 to the wheels stock. I picked up a little over 50hp.
The 160 T-stat allows the car's coolant to run cooler (ie turns fans on earlier) which gives more timing and less of a performance hit once it would normally start heating up. I had planned to do a Paxton Novi Supercharger this year but fell short on the financial end. That yields about 600whp, remove the restrictor plate on the supercharge intake, and tune on meth and 700whp is possible. Problem is at that point traction will be a major issue- if not, and it does get traction at a launch (w/ slicks) the rear may grenade.
Overall a very fun car and believe it or not - my daily. I'm running winter tires on it now. Night and day difference from the MS3 in just about every department- from the way it handles, it's power delivery, and even fuel economy. Surprisingly enough I get better milage in the Vette (27mpg) though that could be because I don't flog it as much. When I do it draw a lot of attention with it's loud exhaust note, and with all of the power it can get squirly.
That said I still, eventually, want to get another MS3, keep the modding to a minimum and use that as my daily.
@ Oaklandopen - I believe it is a C6 and that's not a Z06.. there's no vents for the rear brakes. I thought it was at first when I saw that badge on the side, but then noticed the rest of the car and the power he was putting down was too low for that generation.
Didn't you used to have a Crossfire SRT-6?
Yes- I'm known to move around a lot with cars. I traded the SRT6 in for an SRT4 (caliber) for more room- then the CSRT4 in for the Vette. The Vette has a huuuuge trunk believe it or not.
huuuuge trunk or not, it wasn't in the running for me. The VA state Po frowns on babies in the trunk.
Shave her head?
And there's a blue superbee for sale where I live. I'm allready getting in my rwd v8 mood
