- '13 CWP MS3 & '16 Mazda6 GT
thats a nice car I'd stick to what you said, do what you can N/A and make it handle like a gocart
That's the idea!thats a nice car I'd stick to what you said, do what you can N/A and make it handle like a gocart
Yeah, there are a couple kits out there but it isn't something I've seen often in S5's. I haven't seen too much on superchargers either though a roots style supercharger with ITB's would be pretty sweet. It'd be like old-school muscle car meets rotary. The ITB's themselves probably aren't much, if any performance improvement but when combined with a standalone ECU, aggressive street port and full exhaust I imagine it adds up quite a bit. I am still liking the idea of being able to do away with the air pump, ACV, VDI and 6PI. I'm assuming the VDI and 6PI are things that would go away with the intake manifold?Itb's would be a different direction don't know much about them...or how much can be gained from that. May also want to look into supercharging the car as well.
That's what I meant - the 6 ports are still there but nothing is opening/closing. So I've been piecing together a kit; the big stuff is easy: ITB's, IM, ECU but the smaller things are what are confusing me. Lines and fittings, what ECU sensors (TPS, water temp, etc.) are needed, injector sizes? I imagine I will have to go with an aftermarket FPR and an idle stepper motor with control as well and I suppose there really won't be a primary/secondary fuel rail system anymore either. I'll probably just email Tweakit and see if they can't help me out and piece everything together. This will easily be a $3k+ setup but will no doubt be worth it. Another idea I've been tossing around is lightweight rotors and aluminum housings but those are crazy expensive (they would put a replacement engine upwards of $10k)! So right now the mod work is planned as follows (in no particular order):It does away with the vdi for sure but I believe when you order the itb kits they give you a choice of 6 port or 4 port manifolds. It doesn't do away with them just makes them open all the time.
Such as? I hadn't planned on doing anything to the transmission itself. Just clutch, flywheel, driveshaft and rear differential. I read in your thread about swapping in some MX-5 gears for a lower ratio and that thought has crossed my mind. I don't see myself going balls out for top speed so I may consider this as I value acceleration more. However, I am not going to want to be cruising at high RPM when going 70-75 mph as the noise is probably going to make my ears bleed considering the mods I'm planning.Couple other vendors for your viewing and part pleasure are going to be pineappleracing.com , rx7.com, mmr-direct.com are a few that come to mind.
Any tranny mods planned?
Hmm, I'll definitely have to look into this. Does anyone have any numbers corresponding to the obtainable speeds in each gear?
Got it.Check solomiata.com and mazdatrix has a write up as well
Got it.
So one thing has been buggin me. Is the 6PI actuation in the intake manifold or is it part of the housing? Everything I have been considering is banking on the fact that by switching to a IDA intake manifold I will be removing the 6PI actuation altogether and that the 5th/6th ports will always remain open. I've been looking into this Tweakit ITB setup for quite some time and I'm trying to put everything together. Aside from the kit (with TPS mod and vacuum "channel") I have to source at least the ECU, fuel lines, FPR and injectors. However, I am trying to determine what else will be needed. Because I plan on keeping A/C would a stepper motor be needed? I'm debating on just asking Tweakit but I'm always hesitant to ask vendors what I "need" as I'm sure they will always say I "need" more than I really do. This seems really feasible so I think I'm going to go for it. Most likely I will first fix the current issues with the car, then do the rebuild/street port, then move onto the ITB's with standalone. I just hope the stock computer can keep up with an agressive streetport for a while.
Ah, I see - so how does one "pin" the sleeves open? I'd really like to do the ITB's and street port at the same time and just go with the ECU then. As for the injectors, I'll probably go with four 440cc high impedance units in the ITB housing and block off the rail on the housing (I forget which one that is). I don't know if Pineapple sells the block-offs but I know Racing Beat does. With the Haltech I should be able to progressively run the injectors. From reading on RX7Club several people seem to have success with Emanage, however. I'll try to get in touch with Tweakit sometime soon and I'll also probably give RX7store a call and see if they have any experience tuning this sort of thing (ITB's on a 6-port N/A motor). They are only 1.5 hours up the road after all...The actuators are in the lower intake manifold, the sleeves for the 6pi are in the engine itself. You would just have to rotate the sleeve so its open.
It can't hurt to ask tweakit what you need then compare it against other information your can gather. At least you can get yourself an idea of the max amount of stuff you will need.
Not sure if the stock ecu will be able to keep up or not but you can always pick up a cheap apexi safc to add more fuel or dial in your injectors.
Ohh and for the itb setup you can still run a primary and secondary rail as one set sits directly on the housing. I want to say pineapple racing makes block offs for those if you decide not to run them.
Sure 440's are going to be enough for that setup? I could be wrong but may be worth grabbing some turbo 550cc injectors.
