I need to remove the plastic sill panels on my door frames so i can run the power cable(left side) and rca cables(right side).
I dunno if i'm using the proper term for what these panels are, but it's basically the plastic cover over the bottom of the doorsills that you have to step over to get into the car.
When i pull up on these things to try to pop them off, i can get the curved part to come up with a popping noise like they are unclipping, but the flat part with little bumps on it feels like it is secured much tighter to the body. Does anyone know how these things are attached? If they are glued i don't want to be trying to rip them off, but if they are clipped, how hard do i need to be pulling, at what angle, and do i need to get under them with a prybar or something to lift them off?
