I was just wondering if this is normal on MSP's or if I just need new motor mounts.
Everytime I am driving the car and if I floor a gear up above 5000 rpm or so then switch gears normally (instead of power shifting), the car seems to give a hard thump or push or whatever. I can't explain it. If I shift fast and floor it into next gear it seems okay.
If I drive normal everything is okay. This only happens when I floor a gear and switch normally to the next.
Any ideas on what might be happening. I'm thinking I probably need new mounts. I'm assuming the softer the mounts, the less vibration there will be?
Thanks.
Thanks.
