The shift fork basically holds onto part of the manual tranmission gearing system and moves it up and down. There are 3 forks in our 5 speed tranny. One for 5th/reverse, one for 1st and 2nd, and one for 3rd and 4th. There are 3 "tips" on the geometry of the fork. The 5th/reverse fork only has the two tips that are on either side fo the gear assembly and I can't imagine how that got cracked as that is pretty beefy and also not anywhere where it could be impacted by anything. Must have been a really bad casting on that fork for it to have cracked a tip. The 3/4 and 1/2 forks have an actuator arm on them that has a tip that cracks off when people say they broke their shift fork and are unable to shift in the gears. That has happened enough, but is rather different from what it sounds like happened to you.
