Anyone's best guess while I'm here @ work?
I'll stop by autozone on the way home tonight and get the codes read.
There is no CEL though.
Used 1 can of carb cleaner and found no vac leaks.
pulled the crankcase breather and put my finger over it, no change.
hooked up my mity vac, pulsing showed 17-22hg.
pulsing goes away when AC kicks on to high.
Coolant Temp Sensor measured 965ohms and rose to 1005ohms 10 min later (means it's working)
cleaned maf
I replaced the bov with a straight pipe to eliminate possible source of leak.
I have a turbo w/ blow through maf set up.
also while datalogging w/ WBO2 my rpm's fall before a/f decreases and as the a/f decreases the vac hg increases from -25 to -21hg (af dithers from 14.4 to 17 or so.
Thought it was a leak between maf and TB, or vac leak...
car holds boost (only run 7psi) so I don't think its a leaking egr...
not sure when it started(maybe two weeks ago, ac is on a lot)
uses no antifreeze or oil but I haven' compression tested to rule out HG yet.
didn't know if anyone else knew or has run into this...
thanks, I am stumped...
cleaned maf
