Your going to have to push the windshield washer fluid forward towards the strut tower - just a little bit. Doing that, you will get just a little bit of room, granted it wont stay there without you holding it there, and it is WAY different from the driver side (given the amount of room you have to work with) - but the principles of changing both headlights are the same as explained before me. Pull the rubber boot out, push in and down on the bulb retaining clip, pull the clip open and remove the bulb. The one thing you need to be aware of is if you get Hiper White bulbs or any bulb for that matter that is colored with a blue tint - you will scratch the crap out of it if your not careful - so take your time and be gentle. You will have to turn it clockwise a little bit to make sure that the bulb sits properly, just look into the headlight to make sure that it seats correctly and is not pointing up too obviously.
Secondly - I wouldn't recommend wearing a watch or anything while you try to change your headlight - it makes it all the more difficult to change that passenger side bulb. Not to mention you will scratch the crap out of your arm, have a tight fit, and also scratch your watch. The less on your wrists, the less you have to worry about something else while your changing your headlight.
