So my rear caliper, passenger, siezed up and i replaced both rear calipers. I had to since the allen key mechanism rusted and i couldn't back out the pads. Got new calipers in but i can't seem to get the adjustments right. here's the situation: new calipers/pads/rotors. I tightened the allen key so that the wheel cannot spin freely. Then i backed it out 2/3 of the way. The wheels were not spinning freely so i had to back it out a bit more until the wheels are somewhat spinning freely. adjusting and testing a few times because it would either not engange or not let go when i tested it using the ebrake on a slight incline. Bled the brakes several times to be sure. It works now but my e brake does not fully engage for some reason and my car still slides back on an incline. I tightened the adjustment screw by the ebrake to the max as well. My questions is this seemily an issue with my calipers or is the e brake system not engaging enough?
Sorry for the drawn out explanation but it's an issue that has been driving me nuts.
