Once in a while, there is Group-Buy offered for the Clunk/Klunk Fix. "pw~mp5" (User on this forum) offered it when I bought it about 1.5 years ago. I saw another Group Buy being offered since then, but it's been a while so it's probably done by now. Try PM'ing 'pw~mp5', maybe he's planning another GB, or has a kit left over he can sell you.
From what I understand, the Clunk-Fix doesn't get rid of the Clunk. It prevents it (or "delays it" - would be more accurate) from happening *again* after you've fixed the problem.
Replacing your end-links gets rid of the Clunk noise. Installing the Clunk-fix reduces the sway-bar bending, thus reducing the stress on end-links, thus preventing (somewhat) the Clunk from coming back. So after you get the Clunk-fix (if you can find the kit), you'll still need to replace the end-links. Also, you should replace your sway-bar bushings with polyurethane ones too. The bending of the sway-bar, wears off the bushings too. Worn off bushing = squeaky sound. Polyurethane bushings will last longer then sh!ty OEM Mazda ones.
Before the Clunk Fix, my bushings would last for about 3 months (tops). Sway-Bar End-links, maybe 6 months. After the clunk-fix was installed, my end-links are still holding (Yes, I replaced them when I put in the Clunk-fix). My [polyurethane] bushings (Yes, I replaced them too when I put in the Clunk-fix) are noisy now, but they have lasted much longer then the 3 months that they used to last for (before the Clunk-fix).
