Found why our clutch stopped working at the autox yesterday. The nut holding the clutch hub onto the input shaft worked itself very loose. An impact and some loctite will fix that so it doesn't happen again.
Took the side cover off to check out the shifter mechanism to make sure everything was good under the covers. The shifter rockers are behind the clutch gear (big ring).
