shane02pro5
25ish_psi
- New Caney TX
Time has come to part ways with my Baby and Daily driver of 17yrs. After just putting in the new turbo setup and getting ready to do some tuning, the engine started stumbling during downshifts which unfortunately turned out to be a worn thrust washer that slightly scared the crankshaft surface. I no longer work 1.5 miles down the road so a FWD racecar for a daily is no longer an option.
Paypal & email: p5tshane@yahoo.com
PM or email for faster reply
Haltech F10A with Datalogging all sensors and a 3 Bar Map Sensor (up to 29psi. Several Maps loaded for 3 bar with 285cc/565cc/635cc/750cc Injectors and still maybe a few from the 2 bar map (up to 14.5psi)
$450 + Shipping SOLD
Speedcircuit Stage 1 Cylinder Head
$500 + Shipping SOLD
ARP Head Studs Torques Once
$70+ Shipping SOLD
Garrett GT3071R Dual Ball Bearing T25 Turbo W/ Internal Wastegate
Turbine 56.5mm w/ 84 Trim .64 A/R Housing
Compressor 71mm 56 trim .50 A/R 3" Anti-surge Housing
Hasn't seen past 10psi (Ran low boost until I rebuilt my Transmission before my motor died and I gave up)
8-10psi WGA, Coolant, Oil feed and return lines included
Cold air Intake w/ ATP filter thrown in for free. Setup for a reverse cowl hood but can be cut and resprayed with bbq flat black. Must relocate coolant overflow.
$900+ Shipping SOLD
PAR Engineering 1-4 Straightcut Synchromesh Gearset W/ PAR Input Shaft
OEM Output Shaft Machined and Selector Hubs Machined for Needle Roller Bearings & Double Synchros
1-3 are double synchro & 4th is single synchro. Extra double synchro included
Excellent Condition
All new bearings & Shiftforks (I may be missing 1 bearing)
No additional machining needed (drop in & shim)
Gear Ratios:
1st- 3.11
2nd- 1.83
3rd- 1.24
4th- .90
4th Gear has had a couple small imperfections since new that I have replaced with brand new from PAR. The mating 4th pinion gear is in perfect shape. Everything is perfect and will run smooth as butter!
Final Drive is same as OEM 4.11
$2500+ Shipping (New cost $4100) SOLD
$70+ Shipping SOLD
$900+ Shipping SOLD
Excellent Condition
Gear Ratios:
1st- 3.11
2nd- 1.83
3rd- 1.24
4th- .90
