So, I was just thinking about this. I really don't need to worry for a bit, my car isn't up for testing till 2009, but I just want to have an idea ahead of time. I'm asking in here because this is related mostly to our OBDII system.
I'm looking at gettng the Corksport Downpipe/Midpipe combo, then gutting the second cat for now, as getting the full turbo back is cost prohibitive. Even then, I'm not sure getting the full turbo back would solve the issue I'm thinking off. And that is the dreaded Emissions Test.
Politics of Global Warming and pollution aside, I'm not exactly a huge fan of these tests. Especially seeing as I am planning on basically running an open turbo exhaust, for lack of a better term. However, a bit of research shows that in Texas and in my county, emmisions testing is done via OBDII plug in. A bit of research shows that all they do is get the cats warmed up, plug in the sensor, and then the sensor tells them if their is something wrong or not. Please, feel free to correct me if I am mistaken in the process, I'm not much in the way electrical systems and terms. It did not say anything specifically about a sniffer test or a visual check, but the Corksport Downpipe and keeping the visual appearence of a second cat would help me out there.
So, that being the case, it would lead me to believe if the system thinks there are cats or that the emmisions control is working properlly, even if I had a dump pipe I would still, in theory, pass.
So finally, here is/are my question(s)
1. The downpipe comes with a "CEL Eliminator". I'm I right in thinking that it is an o2 simulator?
2. If the Midpipe deletes the downstream cat, will it throw an emmisions CEL?
3. Is there a CEL Eliminator/o2 sim for the Midpipe? Is one even needed?
4. With the proper set up (CEL Eliminator plugged in up front and a possible CEL Eliminator in the mid pipe), I should, in theory, pass emmisions, correct?
Any and all help, as always, would be appricated. And please, don't say "just get the CP-e down pipe with the high flow cat."
