You aren't looking at the whole picture. N/A ECUs will lean out the mixture some. but thats not the problem. the mp3 ECU has a more advanced timing map. With a boosted car like the MSP, you want to retard timing as boost increases and then advance again. With the more advanced timing with the mp3 ECU , you will more than likely experience detonation as soon as you start boosting. Don't make that mistake. Keep the Msp ECU and tune with a piggyback. No need to question the guys response either. He gave you an honest answer, which is the truth. If you don't like the answer, don't post on the forum. You need to read up on the basics of tuning with a boosted car before you make a costly mistake and end up replacing your engine
