Darth Vader
Har!
I'm in the Forge camp, as MSMS3 knows. I found my stock valve causing unreasonable flutter and soft throttle response in daily driving, with an intake installed. It DID NOT leak at high boost. The Forge holds boost to the same values at high pressure and bangs open and closed ALOT faster, which fits with the test results, to a point. The Forge V1 ain't subtle, with its noise and sharp driveline shock due to the heavy spring I use and the fast open/close but, I don't mind that, this is a total "me first" car, rather than an "after you". (drive2)
