Outlawstar98
Kyle Dampman
2003 Mazdaspeed Protege
Performance Mods -
GT3071R
K1 Long Rods (8.8:1)
Wiseco Pistons (.020 overbore)
Custom Made 3/4" Thermostat Spacer
Custom Made Oil Temp Gauge Connector
Braided Oil Lines
Cometic Multi Layer Steel Head Gasket
ARP Head Studs
ARP Main Studs
ARP Exhaust Mani Studs
ACL Engine Bearing Kit
3 Angle Valve Job (rebuilt head with all OEM Parts)
SteedSpeed Turbo Mani Ceramic Coated
ATP Wastegate Actuator
NGK ZFR7F Spark Plugs
Custom 3" Short Ram Intake with TurboHoses Filter
Perrin Fuel Rail
Updated Welded LSD
Spec Stage 2+ Clutch
Fidanza 7lb Aluminum Flywheel
TurboLife's FMIC
TurboXS RRFL BOV
Medieval Front Motor Mount
Medieval Rear Motor Mount
Medieval Passenger Motor Mount
Medieval Transmission Motor Mount
Medieval Light Weight Powersteering Pulley
Medieval Light Weight Water Pump Pulley
PEP's 3" Downpipe Ceramic Coated
Perrin Catless 3' Exhaust (w/ Vibrant O2 Simulator)
Suspension Mods -
GT Spec Frount Strut
GT Spec Rear Reinforcement Pannel
GT Spec Rear V Brace
GT Spec Four Point Lader Bar
GT Spec Trunk Cage
Fortune Auto Coilovers
Custom Front Endlinks
Custom Rear Endlinks
AAC Adjustable Rear Link Kit
AXR Anti Clunk Fix Brackets
Rotora Slotted Rotors
EBC Greenstuff Brake Pads
Stock Racing Heart Wheels Painted Gold
215/45/17 Bridgestone Potenza RE50A Pole Position Tires
Alignment Specs - 1.7 Degrees in front and 2.2 Degrees of camber in the rear
Interior Mods -
PedoBear Co-Pilot
DGM Carbon Fiber A Pillars w/ Gauge Pod
DGM Carbon Fiber E-Brake Surround
DGM Carbon Fiber Radio Surround
AutoMeter Boost/Vac Gauge
AutoMeter Oil Temperature Sensor
AutoMeter Oil Pressure
AEM Wideband 02
Dave B Rings
2003.5 Gauge Cluster
GloShift 3 Gauge Din
Sony Headunit
Wedge Racing Seat Bracket
Sparco Fighter Racing Seat
APC Carbon Fiber Shift Knob
Exterior Mods -
ProSport Carbon Fiber Hood Dampers
DGM Carbon Fiber Eyelids
DGM Carbon Fiber Mirror Covers
DGM Carbon Fiber Grille
Carbon Fiber Gas Door
Carbon Fiber Pillar Trim
HomeGroundFab Carbon Fiber Devision Plate
XC CF Trunk
XC Carbon Fiber Hood
EDM Tail Lights
HID 6000k Kit
Matt V Projector Retrofit Headlights
2003.5 MSP Lip
JDP Carbon Fiber Spliter
iSport Carbon Fiber Fenders
iSport Rear Diffuser
nk2a Bumper Sag Fix
Engine Dress Up Washers
Muteki SR48 Neo Chrome Lug Nuts
Awards Won -
1. "Lowest Power Output & Good Sport Award; JSC Speed Dyno Contest June 13th 2009"
(PS. that was before the build
2. "Top 50 award" 3rd annual fall fling car show, September 18, 2011
not yellow
zachary
2009 Mazdaspeed3 Grand Touring
<style>*<!-- /* Font Definitions */ @font-face {font-family:"Times New Roman"; panose-1:0 2 2 6 3 5 4 5 2 3; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:50331648 0 0 0 1 0;} @font-face {font-family:Optima; panose-1:0 2 0 5 3 6 0 0 2 0; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:50331648 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:20.0pt; font-family:Optima;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> <style> <!-- /* Font Definitions */ @font-face {font-family:"Times New Roman"; panose-1:0 2 2 6 3 5 4 5 2 3; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:50331648 0 0 0 1 0;} @font-face {font-family:Optima; panose-1:0 2 0 5 3 6 0 0 2 0; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:50331648 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:20.0pt; font-family:Optima;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style>
wheels/suspension:
H&R coilovers
painted calipers (black)
hawk HP plus brake pads
progress 32mm rear sway bar
mazdaspeed CF valve caps
hasegawa lug nuts (black)
muteki forged lug nuts (orange)
rolled and trimmed rear fenders
racing sparco NT-R 18x8/18x9 +42/+45 w/ nitto NT0-5 in 235/40
private reserve 18x8 +40 w/ hankook ventus V12 evo K110 in 215/40
mazda RX-8 18x8 +50 custom finished in bronze w/ goodyear eagle GT in 235/40 and 6mm spacers
exterior:
clear rear reflectors
JDM window visors
tinted fog lights 35%
autoexe stubby antenna
plasti-dip front emblem (white)
personalized plates “CWP MS3”
whited out rear turn signal bulbs
“chrome” front turn signal bulbs
window tint 20% rear, 35% front
pink barbie hair brush drift charm
front lip splitters with JDM ziptie whiskers
deleted rear wiper, door moldings, rear emblems, license plate lights
under/inside:
304g test pipe
TWM short shifter
custom trunk liner
hydraulic hood props
cobb turbo inlet pipe
cobb short ram intake
aluminum shifter bushings
SU aluminum oil filler cap
TWM A6 leopard shifter knob
custom urban camo shift boot
CPE 75 duro rear motor mount
all interior lights swapped for LEDs
CityRacer
Christopher
1993 Ford Probe~Mazda~2.0 fsde engine + g series trans + suspension + brakes
Engine+trans:
Mazda~2.0 FSDE
Wiseco 8.7:1
K1~connecting rods
clevite~bearings
Arp main studs
cometic extra thick head gasket
oil pump relief valve shimmed 6mm
oil pan tapped for turbo return line
Blocked bored to 84mm
rotating assembly balanced and blueprinted
Arp head studs
CorkSport stainless steel valves
Eibach valve springs
Mazda~solid lifter conversion
heavy port and polished head
adjustable cam gears (both intake+exhaust)
fsze intake cam
fsde exhaust cam
obx turbo manifold
arp stainless steel exhaust studs
Precision Turbo~GT30R: .48ar~t+.60ar~c
Tial 38mm wastegate~15lb spring
stainless steel dump and wastegate tubes + vband connection to exhaust
Aluminum intercooler piping + 28x12x3 front mount intercooler
Synapse Synchronic Blow Off Valve~recirculated
Gizmo Electric Boost Controller~tuned up to 28psi+scramble boost mode
Aluminum turbo inlet + wire mesh intake filter
EGR + IAC removed with metal plates installed now
cold idle solenoid + wire mesh intake (closes at 99 degrees water temp~good for about 400rpms)
billet check valve for cold idle solenoid
Aluminum pulley =water+power steering
Protege power steering pump conversion
140amp High output alternator + custom overdrive pulley
unorthodox racing aluminum under drive pulley plus crank sensor magnets
custom crank sensor bracket
twin catch can system vented into the drivers wheel well
WeaponR~engine torque damper: bolted to lower trans and center cross member
AWR rear, pass side, and front engine mounts
rebuilt and braced passenger engine mount to body area (tore the mount from the body, had to get it rebuilt stronger)
Twin walbro pumps = 190 in tank+255 in line
Aeromotive rising rate fuel pressure regulator
RCE 650cc injectors
shureflo 150 pump into m4 nozzle (water injection)
NGK spark plugs
NGK Spark plug wires
MSD high vibration ignition coil
MSD high vibration ignition box
polished caps ~ coolant/washer/brake/power steering
polished fuse box lid cover
RonDavis aluminum radiator + 18psi cap / 180o thermostat
polished aluminum radiator cover plate
stainless steel radiator lines
Accusump 1qt + manual valve + in line check valve
oil cooler + thermostatic bypass + sandwich plate + remote ZR1 oil filter+ filter magnet (half moon style)
aluminum heat shielding on anything non metal around the turbo/manifold
mild steel exhaust + resonator + oval straight through glass packed muffler + rusty tip (trying to be somewhat incognito)
corksport ~ eurathane exhaust hangers
RR-Racing short shifter + poly linkage bushings
Spec 4+ clutch (non sprung full faced disc)
Spec aluminum flywheel
Quaife Limited Slip Differential
PAR straight cut 3rd gear
PAR billet trans case bearing cups
stainless steel clutch line
Noe trans fluid
WS2 (tungsten disulfied) added every oil change
Suspension+Brakes:
Tein SS coilovers with front camber plates
corksport front control arm bushings
AWR front adjustable sway bar attachments
King6Fab custom front cradle with integrated control arm support brackets
Addco rear sway bar
King6Fab rear sway bar attachments for Megan Racing lateral arms
Megan racing rear adjustable lateral arms
Megan racing front strut bar
GT-Spec aluminum trailing arms
GT-Spec Aluminum v-brace
GT-Spec rear sub frame center brace
Aluminum brake booster vacuum canister + check valve
k-sport 8-piston front brakes with 13" floating rotors + race pads
6" front brake ducts
MazdaSpeed Protege rear brakes + EBC Yellow brake pads
k-sport hydraulic hand brake
stainless steel brake lines all four corners
ARP wheel studs
redesigned & replaced rear brake hard lines
welded 1"x2" unibody bracing
welded 1"x2" rear strut housing brace
Exterior:
Aerogear ~ Evo front bumper (modified+molded in turn signals)
Aerogear ~ millenium rear bumper (molded)
Aerogear ~ shogun side skirts (molded)
aluminum tail light center filler (molded)
custom painted tail lights
CarbonFiber ~ head light covers (1 of 15 made)
CarbonFiber ~ rear hatch (1 of 15 made)
CarbonFiber ~ rear spoiler (1 of a kind)
CarbonFiber ~ front hood ("Chris's Toy"stenciled under side of hood)
CarbonFiber ~ engine cover
CarbonFiber ~ front bumper filler
12v Shark fin antenna
gas hood props
raised hood spacers
stainless hood pins
BMW windshield sprayer pump
windshield spray nozzles relocated to wiper arms
wiper arm pressure spring braces
clear side markers
led bulbs ~ corner, side markers, and tail lights
6" rally driving lights + rock guards + dark tint films
quad H3 projector HID lights+relays+capacitors
front diffuser back to wheel wells + 3 frame mounts (also serves as an impact guard for the front bumper-very strong)
rear diffuser from wheel wells to rear bumper edge + 3 frame mounts &2 bumper mounts
front 3/4" wheel spacers with the adapter studs
Kosei K1TS graphite 14lb 17" wheels
Dunlop ~ StarSpecs & WinterSport 3ds
Led rear license plate back up light (super brite leds)
black front emblem change
limo tinted back + quarter windows
front removable tow hook bolted to drivers frame rail
interior:
black conversion from blue=carpet+panels+dash+head liner+custom rear compartment
Ultra suede over thick foam rear compartment ( all the way to the trunk)
roll bar & strut brace foam padding + black fabric wrap
AutoPower Race rollbar
RCI 5-point passenger harness
TeamTech 8-point (custom) driver~jet pilot harness + integrated lumbar & energy dispensation padding
matte black dash cover (to kill reflection from the dash)
Sparco Road Line pedals (positioned for heal toe)
TenzoR ~ Rally seats
TenzoR ~ Steering wheel
Sparco ~ Steering wheel adapter
PorsheRacing ~ steering quick release
1" aluminum steering wheel spacers (2= 5" total closer to driver for modified drivers positioning)
horn relocated to steering column + aftermarket button
TWM ~ shift nob
Leather shift lever boot
Center console delete
fuel mixture "on the fly" adjustment nob mounted into custom lower center dash panel
kill switches ~ ecu/fan/water injection/master power
led indicator lights ~ accuvolt/water injection/ecu fault/knock system
gauges ~ ammeter/water temp/oil pressure/fuel pressure/wide band o2/fuel level/system voltage/vacuum boost/egts
Sony xplode head unit
Focal front speakers
Infiniti rear speakers
JBL w3v3 sub+box (under 15lbs & easily removable for track days)
RockfordFosgate punch amp
kinetik hc1800 battery
battery to trunk relocation + zero gauge wire & 300amp fuse
full vehicle rewire from bumper to bumper
Jacobs electronics Accuvolt
aluminum+carbonfiber shield for Accuvolt
J&S safeguard + launch control/flat foot shifting/knock&a/f gauge
Cooling mist vericool water injection controller
SDS EM4E fuel and ignition system
Trackmate GPS dataloger system
ChaseCam video system
i-shift programmable led shift lights
fire extinguisher + roll bar quick release mounts
Midland (car to pit) 2 way radio system
2 additional 12v outlets
Accomplishments?
Simply that I still have her. Been in a wheelchair for a year now, and others have had to drive my car for me. She's still mine though, and I keep her in good shape. A dyno vid to show she is real.
dyno
And a friend of mine on a track last summer.
lapping day
*I'm the only one I know of who has shattered a Pauter rod.
lol
RichB
Rich
2007 Mazdaspeed 3 Grand Touring
Engine
CP-E Cold Air Intake (Painted Black)
CP-E Top Mount Intercooler
Turbosmart Dual Port Blow-Off Valve (SU Black/Red Edition)
Corksport Power Series 80mm Catback Exhaust
COBB Accessport
Corksport Rear Engine Mount Inserts
Mobil 1 0W-30
Transmission
TWM Performance Short Shifter
TWM Performance Shifter Bushings
COBB Shifter Weight
Redline MT-90
Wheels / Tires / Suspension
(Winter) Stock Mazdaspeed 3 18 X 7 .5 Rims wrapped in 215/45 R18 GoodYear Eagle GT All Season Tires
(Summer) Mazda RX-8 18 X 8 Rims Powder Coated Bronze wrapped in 235/40 R18 Hankook V12 Summer Tires
Mazda Center Caps Painted Black (For RX-8 Wheels)
Black Muteki Lugs (For RX-8 Wheels)
KW Variant 1 Coilovers
Hotchkis Rear Sway Bar
Brake Calipers Painted Red
Interior
OEM Mazda Navigation System
Single Gauge Ventpod
Aero Force Scan Gauge
TWM Performance Matte Black Type R Shift Knob with Etched 6 Gear Pattern that is Painted Red
TWM Performance Shift Boot
Exterior
RHO Front Tow Plate Holder
Windows Tinted to 20%
Debadged "Mazdaspeed 3" From Rear Hatch
Rear Fenders Rolled
JDM-P5
Phil B.
2006 White Water Pearl Mazdaspeed6 GT
Engine
Option Racing Short Ram Intake
Protege Garage Turbo Inlet Pipe
CP-E Single Exit Cat-back Exhaust
HKS SSQV BOV
Exterior
Auto Exe front grill
Prolight CF Mirrors
Xentec HID Headlight Bulbs
Xentec HID Foglight Conversion Kit
Wheels/Suspension
Rays Gram Lights 57 Pro
BC Racing BR Coilovers
Awards
2nd Place Import Stock (Joint Base Andrews Car Show 2010)
1st Place Import Modified (Joint Base Andrews Car Show 2011)
Protege03ak46
Adam
2003 Protege LX
Suspension Mods:
-"Custom" Fortune Auto 500 Series Coilovers 6k/8k front/rear
-Racingbeat rear sway bar
-Rear strut brace
-Full set of AAC End Links
-5-lug, 4 corner disc brake swap
-AAC Adjustable rear link kit
-US Brake DOT4 600+ fluid
Wheels, Tires and Brakes:
-MB Weapons
Front:
-17x9 +27
-~1.5 degrees of camber
-rolled fenders
-minimal rubbing, except when turning
Rear:
-17x9 +27
-~2.5 degrees of camber
-rolled and pulled fenders
-rubs a lot
- 205/40 R17 Front/ 215/40 Rear
-Muteki lug nuts
-R1 Concepts slotted rotors
-Hawk pads
-Corksport SS lines
Exterior:
-Protege sedan front lip
-Custom full splitter
-Rain visors
-Bumper latches
-Cut out front grill
-6k HID Headlights
-All red tails
-Completely debadged
-Hella Horns
-Camo vinyl fender
-GT-300 Fiberglass Rear Diffuser
-Sheet Aluminium Rear Spoiler
Engine:
-Exedy Stage 1 Clutch
-RAI
-AC delete
-2 1/4" Cat-back exhaust with bozo style tip
Interior:
-MSP STS
-CorkSport shifter bushings
-Megan STS
-Custom shift extension
-NissanParts shift knob
-Speedway Motors 13" Karting Wheel
-5 panal mirror
-NRG bucket seats
-Harness bar
-Orange RJS Racing 5-point harness
Accomplishments/Features::
MazdaFitment: "Mini Mazda Invasion!"
http://mazdafitment.com/2011/04/09/mini-mazda-invasion/
NW-Built: "Mini Mazda Invasion!"
http://nw-built.com/?p=1054
NW-Built: "Adam's Protege Update" -
http://nw-built.com/?p=1038
NW-Built: "Random Roller: Adam's Protege" -
http://nw-built.com/?p=964
Rustyairland: "one of my fav Proteg out there!" -
http://rustyairland.wordpress.com/2011/03/17/one-of-my-fav-protege-out-there/
Almost Evil: ”He’s special” -
http://almost/evilcrew.com/?p=486
NW-Built: "Ever See a Protege Like This?!" -
http://nw-built.com/?p=102
MSP SuperStreet
Karl and Logan
2003.5 Mazdaspeed Protege
#357
Engine Performance Mods:
- Engine Swap 2.0L Forged Short Block
- Precision 5557E Turbo with Ball Bearing and PTE Billet Wheel
- Microtech LT10s Engine Management System
- SteedSpeed CNC Turbo Exhaust Manifold
- TurboLife Hi-Volume Performance Front Mount Intercooler
- Performance 440 Fuel Injectors
- Mazdaspeed Crankshaft
- Pauter Forged Connecting Rods
- Clevite 77 Connecting Rod Bearings Set
- CP Pistons 8.5:1 CR/0.20 Bore
- TiAl MV-S External Wastegate with Dump Tube
- Clevite 77 Main Bearing Set
- Clevite 77 Thrust Washer Set
- ARP Head Stud Kit
- ZEX Wet Nitrous System with 55hp Shot Nozzle
- ZEX 10 lb. Bottle with Warmer
- ZEX Tuner Kit & Remote Nitrous Remote Bottle Opener
- ZEX Hyperformance Nitrous Spark Plugs
- ZEX Dual Nitrous Purge System
- Nitrous Express N-ter Cooler Sprayer System, 10 lb Bottle
- Nitrous Express Nitrous Bottle Opener
- Custom Billet Nitrous Bottle Brackets
- HKS Super Sequential Blow-off Valve
- Hallman Pro RX Boost Controller
- Pivot Turbo Timer with Red LED Display
- SC-Custom 3” Polished Aluminum Turbo Hard Piping
- SC –Custom 3” Performance Downpipe
- Injen RD Series Cold-Air-Intake (CAI) Polished Aluminum
- ASP Custom 3” Stainless Steel Exhaust w/Carbon Fiber Muffler
- High Output 140 AMP Alternator
- Medieval High Performance Light Weight Crank Pulley
- Medieval High Performance Light Weight Power Steering Pulley
- Medieval High Performance Light Weight Water Pump Pulley
- Medieval High Performance Light Weight Alternator Pulley
- Mistimoto High Performance Slim Fan
- OBX Billet Vacuum Manifold Block
- Racing Radiator Overflow Tank
Engine Appearance Mods:
- DG Motorsports Custom Airbrushed Carbon Fiber Engine Cover
- Aluminum Air Diversion Plate
- Carbon Fiber Radiator Cover
- Custom Chrome Strut Bar
- Hayame Billet & Carbon Fiber Brake Fluid Cap Cover
- Hayame Billet & Carbon Fiber Power Steering Fluid Cap Cover
- Mazdaspeed Billet Oil Cap
- Billet High Pressure Radiator Cap 1.3kg/cm2
Brake/Suspension Mods:
- Magnum Crossed Drilled Rotors with CadPlating, PBR Pads
- K-Sport Performance 36 Way Fully Adjustable Coilovers
Exterior Mods:
- Tinted Windows, 26%
- Custom Painted Carbon Fiber Evo Hood
- Hayame “gun metal” hood pins
- Blue 8500K Xenon HID Bulbs
- Tinted Altezza Tail Lights
- Tinted Headlights
- Hella Angel Eyes Fog Lights
- Carbon Fiber Grill
- Carbon Fiber Gas Door
- Carbon Fiber Fog Light Deletes
- Carbon Fiber Rear Latch Cover
- Carbon Fiber Side Splitters
- Carbon Fiber 3 Piece Side Pillar Covers
- Carbon Fiber License Plate Frames
- Mazdaspeed Front Grill Badge
- Custom Aluminum “MSP SuperStreet”Emblem
Interior Mods:
- Tri-pod A-pillar
- Autometer Carbon Fiber Boost Gauge
- Autometer Carbon Fiber Pyro Gauge
- Autometer Carbon Fiber Air/Fuel Gauge
- Autometer Carbon Fiber Oil Pressure Gauge
- Autometer Carbon Fiber Volt Gauge
- Custom Carbon Fiber Dual Frog Eye Gauge Pod
- Custom Dual Gauge Surround
- Two Autometer Carbon Fiber Electronic Nitrous Pressure Gauges
- Carbon Fiber Radio Surround Bezel
- Carbon Fiber Gauge Bezel
- Carbon Fiber Shift Plate
- Brushed Aluminum Accent Gage Rings
- Custom Carbon Fiber Nitrous Control Panel with Ignited
Toggle Switches and Purge Buttons
- Center Console with Audison Bass Adjustment Control
- Polished Aluminum Diamond Plate Floor Mats
- Carbon Fiber Shift Boot with Accent Yellow Stitching
- Carbon Fiber Center Arm Rest
- Carbon Fiber Glove Box Cover
- Carbon Fiber E-brake Cover
- Carbon Fiber Aluminum Dead Pedal
- Custom Yellow Kevlar/Carbon Fiber Headliner
- Custom Yellow Kevlar/Carbon Fiber Wrapped Pillars
Car Entertainment, Security & Electronic Mods:
7 Monitors/TVs, PS2, Video-IPOD, Satellite-FM-AM Radio, DVD&CD
- Alpine IVA-D310 Multi-Media Mobile Audio System
7” Touch Screen LCD/TV DVD/CD/IPod 30G, Sirius Satellite Radio.
- Alpine KCA-420 Multimedia IPOD System with IPOD 30G Video
- 2 Alpine 10” Monitors Mounted in Custom Fiberglass Trunk
Lid Enclosure with 2 Mounted Hertz ECK130.3 5.25 Coax Speakers
- Audio Control DQX Processor (EQ/Crossover) Chrome Yellow
- Audison LRX5.1K 5 Channel Amplifier
- 2 Hertz HX 10” Subwoofers
- Custom Fabricated Fiberglass Dual Subwoofer Trunk Enclosure
- 2 LCD 7” Driver and Passenger Visor Monitors
- 2 AcceleVision LCD 7” Swivel LCD Headrest Monitors
- Sony Playstation 2 with Logitech Wireless Controllers
- Custom Fabricated fiberglass and Carbon Fiber Rear Deck
Enclosure for Playstation and pair of Hertz 130.3 Coax Speakers
- Hertz ESK163.3 3way component System
- Custom Fabricated Carbon Fiber Pillar Tweeter Speaker Pods
- Custom Fabricated Carbon Fiber Door Panel Speaker Pods
- Custom Carbon Fiber/Kevlar behind Rear Seat Audio/Video
Component Enclosure.
- Full Roadkill Sound Damping Material
- Viper 5000 Car Security System, back-up Battery & Full Compliment
of Sensors
- Escort Passport SR7 Remote Radar Detector
- Escort ZR3 Laser Shifter Defense System
- 2 Stinger Compact Dry Cell Batteries
- Custom Fusing Display Under Hood
- Custom Built RCA and Video Signal Cables
- Complete Stinger Power Wiring
Car Show Awards
2006
Extreme Auto Fest Bandimere Speedway
1st Place Best Mazda
Street Customs of the Rockies Car Show
2nd Place Best Mazda
Street Tuner Mayhem Bandimere Speedway
2007
Annual Spring Dust Off Car Show
2nd Place Sickest Mazda
ZOOM ZOOM BOOM – Engine Rebuilt: June 2007 – September 2008
2008
Colorado Mazda Club Birthday Bash
1st Place Heavily Modified Mazda
1st Place Best In Car Entertainment
2009
Brighton Colorado Car Show
1st Place Best Import
Take Back Summer Car Show
1st Place Best Asian Import
Car Toys Traffic Jam Car Show Denver
2nd Place 4 Door Wild Import
5150 Rize and Shine Car Show Denver
1st Place Asian Import
Rocky Mountain Hot August Nights
2nd Place Import/Sport Compact
World Tuner Challenge Bandimere Speedway
Import - Best Of Show
2010
Import Face Off
Turbo Upgrade: July – September 2010
2011
Top 5 – Elite Show Car
5280 AutoFest Car Show
Best Mazda
Recognition
Featured Ride December 2008
Colorado Mazda Club Form
