Herblenny
Phil Sohn
1993 RX7
Engine:
- Adaptronic ECU for FD PNP (
http://www.turblown.net/store/index.php?productID=280)
- Garfinkle Delrin Custom mounts
- Pettit Polished AST
- Koyo N-Flow Radiator
- Custom Carbon Fiber Cooling panel
- Fast acting AirTemp sensor
- BNR Stage 3 Twin Turbos
- Ported 13B-REW engine
- Custom Grounding kit
- Polished Efini Y-pipe
- Polished upper intake manifold
- Polished 90mm Rotary Works Throttle body
- Polished Greddy elbow w/injector ports
- Apexi GT Spec FMIC
- Custom polished pipings By: BNRSupercars.com
- Constant tension T-blot clamps for IC pipings and Intakes.
- HKS seq. BOV
- HKS twinpower ignition amp
- RE-Amemiya SS Dual Dolphin Tip Catback
- SS Pettit DP
- Mazdaspeed ignition wires
- FEED oil filler cap
- FEED coolant filler cap
- Added R1 Dual oil coolers
- Braille light battery
- Braille Verticle mounting kit
- Unorthodox Alternator pulley (red)
- Unorthodox Power steering pulley(blue)
- Exedy Hyper Single Clutch Kit
- Simplified seq twin set up
- Polished hardline intake pipes for secondary intake.
- Ported JDM Upper Intake manifold and polished by David Garfinkle.
- Also all the misc. vacuum ports have been welded shut and cleaned up and polished for cleaner look.
- Pettit Racing water pump pulley
- 2 x 4 blade fan set up for better cooling
- HKS RS intake with KN filters
- Tweakit Racing tensioner pulley kit
Suspension:
- M2 launch kit
- FEED coilovers
- Fender Braces
- Racing Beat sway bar brace
- Racing Beat sway bars (front and rear)
- AutoEXE front brace
- Racing Brake Rear Brake kit with HP+ pad
- Hawk HP+ pads rear
- Newly sandblasted A-arms and other suspension parts
- SakeBomb AP Racing Big Brake Kit with Ferrado pads
- Braided SS brake lines
- Racing Beat sway bushings
- New Delrin bushings for all suspension parts
- Transmission brace
- Raceshop Rollbar
- Dragon’s diff brace
- Rays Engineering Volk Racing RE30 Diamond Black 189.5 Front and 1810.5 Rear with GT limited Carbon Fiber center caps.
- Toyo R888s 255/35 front and 295/30 rear
Interior & Stereo:
- Works Bell Short hub
- Works Bell Quick disconnect
- Works Bell hub lock
- Personal Steering wheel
- Converted Black interior – including, door panels, rear panels, head liner, seat belts, and black main carpet
- RZ floormats
- Rare moon roof interior cover
- JDM rear seats with panels, seat belts, and special rear carpet
- Bride Artis III Navi
- FEED Shift knob
- Red leather stitching shift and ebrake boots
- LED interior lights
- RE-Amemiya steering column pod with 52mm Prosport boost gauge
- JKL Engineering Carbon Fiber Gauge cluster, hood AC panel, shifter,etc (Flattened look)
- JVC 7inch AV system
- RE-Amemiya speedo cluster gauge
- FEED Carbon fiber rear trunk add on.
- Base model hatch cover
- OEM fog light switch to turn FEED HID driving lights
- Carbon look oem door step
Exterior:
- Plasti Dip Storm Cloud Grey exterior (
www.DipYourCar.com)
- Carbon Vented hood
- APR GT300 with custom aluminum stands by Adam Griffith
- One off Feed Carbon Gas door (Shine Auto)
- Feed Type 2R front bumper
- Feed Carbon fiber canards
- Feed Carbon Fiber side skirts
- Feed wide front fenders
- FEED rear wide flares
- Rotary Extreme hood dampers
- R-magic oil cooler ducts
- FEED front tow hook
- Adam Griffith rear tow hook
- RE-Amemiya Pro Carbon rear diffuser
- Custom LED tail lights
- Custom rear bumper CF signal covers
- Rare glass moon roof
- LED signal lights in FEED signals
- HID FEED Signal lights
- Spirit R fender badges
- Efini front are rear badges
- Carbon look rear bumper lights
- Carbon fiber FEED gas door (one off made)
- APR Carbon Fiber side Mirrors
- Custom front canard add on
- Carbon Cooling panel (custom, made by me)
- LED Front bumper strips
- R-Magic HID head lights
- FEED door handles
- Carbon Fiber back of the door handle covers.
- Back Off 3rd light flasher
- ShineAuto rear tail light lip
- Feed carbon Fiber bumper guard by Shine Auto
