ThunderChunk
- Mazda, Protege5 '02
so my headlights went out and so did the foglights at the same time but my parking lights, high beams and tail lights are all fine. i checked the fuses but i dont see anything blown, whatsup?
Did you check the fuse box in the engine compartment?
yeah...nothing looks burnt out
The low beam fuse circuit feeds the fog lights, you said nothing looks burned. You need to pull the fuse and check that it's not open, use a ohm meter or substitute another fuse. You cannot always visually detect a blown fuse.
Not likely to be caused by a voltage surge, that would affect other components.
Clifton
