O orng1 Member : mazdaspeed protege Feb 11, 2005 #1 kg/mm to psi? Does anyone know the conversion rate for kg/mm to psi? Last edited: Feb 11, 2005
R RyanJayG MP3 #1497 Contributor : Yellow MP3 #1497 Feb 11, 2005 #2 http://www.setra.com/tra/app/app_pcc.htm <table valign="TOP" border="1" cellpadding="2" cellspacing="1" width="438"> <tbody><tr><td align="left" valign="top">1 kg/mm<sup>2</sup> (kilogram per square millimetre)</td> <td align="center" valign="top">=</td> <td align="left" valign="top">1422.33 PSI</td></tr></tbody> </table>
O orng1 Member : mazdaspeed protege Feb 11, 2005 #3 thanks that was very helpful. I saved it as I will most likely need it again.
R RyanJayG MP3 #1497 Contributor : Yellow MP3 #1497 Feb 11, 2005 #4 try this: http://www.processassociates.com/process/convert/cf_all.htm for all your future conversion needs (thumb)
O orng1 Member : mazdaspeed protege Feb 11, 2005 #5 thanks I'll set it at 1.2kg/mm for now. on the eclipse that is. msp is running around 9psi
