Myth:
K1 rods aren't strong enough
Fact:
Unless you are making well over 500hp, k1's in the stock length will hold up.
RPM is the killer of rods not the power level. It is a strong H beam design.
"The connecting rod is under tremendous stress from the reciprocating load represented by the piston, actually stretching and relaxing with every rotation, and the load increases rapidly with increasing engine speed."
Myth:
Running lower compression is better.
Fact:
When you drop compression ratio you can run more boost and more ignition advance into boost at a trade off at less power production. Alternatively, you can also raise the knock limit on motors when you change the air flow characteristics of the motor through head work and less restrictive manifolds.
Choosing a compression ratio isn't about running a ton of boost. The right compression ratio is one that works efficiently for your application's intended use and the desired power band. You must also take into account the turbo's efficiency and which boost pressure is in its sweet spot on the compressor map. For example, if you have a low comp motor able to run 25 psi but your turbo efficiency is 20 psi. This is a waste as I see many people running like this. You would have a more responsive and powerful motor if you had picked the right compression for the turbo you plan on using. You want to run on the low end of the turbo efficiency limit on pump gas, so it gives you head room to run race gas or other higher octane alternatives at more boost.
Myth:
Running more boost is better and I'll be faster.
Fact:
First, anything over 250 whp, the handling in this car will be harder to control because of tire spin and torque steer. You will only be faster in a straight line in the higher gears. Second, you can make the same power at less boost. Example would be if you make 300 hp at 16 psi on 9:0 compression or 300 hp at 23 psi on 8.5:1 compression, running the lower boost pressure will be more efficient and less stress on the engine.
Myth:
Brand A piston is better than Brand B because of the compression ratio
Fact:
Comp ratios don't make one piston better than another as they can be made to any comp ratio you want. What you need to do is compare the metal alloy used, machined finish quality, and features such as: friction coatings, balancing, and piston rings and wrist pin and lock design.
