jrodhotrod
Contributor
- 2003 Mazda Protege5 (Mine) 2002 Nissan Sentra GXE (Wife's)
Update - 8-2-06 - Audio Link Install
Update 8-2-06 - Audio Link Install
Not a whole lot to installing the Audio Link. It simply plugs into the port on the back of the factory headunit that is reserved for a CD changer or satellite radio. Plug that cable in, run the other end of the Audio Link cable to where you want your iPod and done.
The Audio Link - http://www.therpmstore.com/product_info.php?cPath=91&products_id=142
Allows you to use an iPod or any other audio device with the factory headunit. No more FM modulator. A bonus about the Audio Link is that it allows you some basic control of the iPod with the steering wheel controls yet still allows you to control the iPod using the iPod itself. Many other iPod interfaces hijack control of the iPod and you can only use the headunit to control your iPod.
Anyways... on to the pictures.
As always, a full set of images is available on Flickr here:
http://www.flickr.com/photos/surfergeek/sets/72157594218443344/
All images here link to full size images on Flickr.
The Audio Link uses a standard Apple 8 pin mini-din cable to interface between the dock connector and the unit. I found the cable that came with the unit to be a little too short for my tastes so I purchased an extension cable that allowed me to mount the unit directly behind the factory stereo and run the dock connector cable into the center console between the seats. From here I can put the iPod in the top portion of the center console, in a cupholder mount, or one of many other places. It is possible to get the cable here without the extension cable, but it's a tight fit.
This image shows where I decide to mount the unit. There is a piece of carpet that runs along the firewall back there that leaves the unit out of the away. I put velcro tape on the back of the Audio Link and zip tied it to the carpet to keep it from moving. I also secured the extension cable to be sure it didn't come unplugged
<a href="http://www.flickr.com/photos/surfergeek/202736987/" title="Photo Sharing"><img src="http://static.flickr.com/69/202736987_c6a1cc826e.jpg" width="500" height="375" alt="Audio Link Installed" /></a>
A second view of where I mounted it to give better perspective.
<a href="http://www.flickr.com/photos/surfergeek/202737012/" title="Photo Sharing"><img src="http://static.flickr.com/76/202737012_0729d60498.jpg" width="500" height="375" alt="Audio Link Installed Again" /></a>
Lastly, this image shows where I chose to route the cable going back to the center console. It is tied down with zip ties to prevent it from going anywhere. You can see it's the whitish cable on the right side of the tunnel.
<a href="http://www.flickr.com/photos/surfergeek/202737046/" title="Photo Sharing"><img src="http://static.flickr.com/62/202737046_839c69eecb.jpg" width="500" height="375" alt="Cable route for Audio Link" /></a>
That's it for this piece. The Audio Link is pretty well documented and the install is nothing special.
