I recently changed the battery in my 2006 Mazda 5 and since
then the cars idle has been pretty wild. Usually the idle after start is fine but when in drive and foot is moved from the accelerator the engine wants to run bouncing between 250 and 750 rpm then sometimes will die. I'm not sure if the problem is related to the battery change (ie. Need to relearn idle) or if this is a new problem not associated with the battery at all. And info would be appriciated.
