R REAL-OC Member : Protege5, 1.6 Dec 17, 2006 #1 Hi, does someone know, if the original side skirts are only screwed, or if they are also gummed? Greets Stephan
A aMaff High Speed Low Drag : 1992 Miata / 2003 Pathfinder Dec 17, 2006 #2 not glued, just plastic fasteners.
R REAL-OC Member : Protege5, 1.6 Dec 17, 2006 #3 Thank you for your fast answer Can someone show me the mounting material I need to mount them?
P Protege2886 Member : '99 Protege Dec 17, 2006 #5 anybody have the mazda part # for these clips ? I need to pick some up so I can install my skirts in the spring
A aMaff High Speed Low Drag : 1992 Miata / 2003 Pathfinder Dec 17, 2006 #6 call mazda? Just say you need the clips and the fastener for the side skirts
M marshall-BJ-VE Member : Mazda Allegro GLX Dec 18, 2006 #8 in this post you'll find part number for fasteners (around 50 bucks getting all of them) http://www.mazdas247.com/forum/showthread.php?t=123653622 I'll ask to my shop to glued it... if is not possible then I'll get fasteners.
