thanks yall, actually doing this was pretty easy, the hardest pair was probably aligning the projector so that the horizontal beam pattern would be nice and straight. after that its just JB weld, high temp silicone couple of springs,screws, and nuts, some aluminum sheetmetal and a ring that i found at ACE hardware that's used for faucets ( this was used for my shroud bezel). here's a good how to done online by melicha8, the only thing different really was the projectors i used ( from audi's called valeo, they fit H7 bulbs so i used existing HID's i had already) and instead of fabricating a mount, i used the reflector bowl as the base and reinforced it with a bit of jb weld.
sorry guys i forgot to take pictures fo the process of making this. but its not very hard, just takes guts and some patience. its very easy trust me.
