Hey guys I recently purchased an 02 Protege5 I've finally decided to toss out that stock stereo for my old deck from my 02 neon, Eclipse CD5030... So i went online searching for a wiring diagram that would allow me to chop off the end and wire me up some good stuff then I ran in to an issue... Upon inspection of the wiring color codes from Modlife, Which this diagram is also used by many other sites as "correct" but if you inspect the actual wiring diagram manual you will see that is not even close to the correct diagram as it mentions not of a pink wire when there is in fact one...
TLDR;
I need help with wiring.. I figured out which is what other then a few small issues
The Portege5's 'Correct' Wiring List
Eclipse CD5030 Wiring:
Which wire does 13 have to go to? G or E or Both?
Do I connect 16 the ground to W or mount it to a post on the inside?
Sorry it's been a few years since I used this deck I have not had the neon in a while and had vehicles in between these two so my memory on how I had it set up in the neon and how this protege5's wiring look are kinda wonky, so any tips or help would be greatly appreciated I feel like it's time to get my kicker sound system re-installed.
TLDR;
PHP:
System:
(W) Black (Thick) - To Battery (-)
(R) Pink w/ Black stripe - Ingition Switch
(G) White w/ Blue stripe - Illumination < Why are there two?
(E) Light Green w/ Black stripe - Illumination < Which one do I use?
(B) Blue w/ Red stripe - Acc (+)
Speakers:
(X) Green w/ Orange - Rear Right (-)
(Y) Green - Rear Right (+)
(U) Brown - Rear Left (-)
(S) Brown w/ White - Rear Left (+)
(F) White - Front Right (-)
(D) Red - Front Right (+)
(C) Black w/ White - Front Left (-)
(A) Black w/ Red - Front Left (+)
PHP:
Speakers:
1. White/Black (Front L Ch -)
2. White (Front L Ch +)
3. Gray (Front R Ch +
4. Gray/Black (Front R Ch -)
5. Green/Black (Rear L Ch -)
6. Green (Rear L Ch +)
7. Purple (Rear R Ch +)
8. Purple/Black (Rear R Ch -)
System:
9. Blue/White (Amp Control +B)
10. Blue (Power Antenna)
11. Brown (Steering 2)
12. Brown/Black (Steering 1)
13. Orange/White (Illumination)
14. Red (Acc +B)
15. Yellow (Backup to Battery) (+)
16. Black (GND)
