HELP: Installing DSM AFC...Vac line route?
Earful
2003 MSP #1323
Hey all,
Installing my DSM AFC this weekend. Going into the glovebox. I currently use a Greddy ProFecB and cant use manifold vac line. I understand I can poss use brake booster if I tap before a check valve. Anyone done this? It looks like a different diameter tubing, so a special T seems in order. Any ideas?
look for the how-to on the brake booster line method. I would use the brake booster for the BOV/BPV source and then use the current vac. line going to the BOV/BPV for the AFC's source.
Thanks, but I am using the manifold vacuum for my Greddy boost controller...searching for brake booster posts.....(RTM)
the manifold vaccume has nothing to do with the boost controler, or the afc. All you need to do is use the brake booster for the bov/bpv source, then use the existing bov/bpv for the AFC source.
