- -- 03 P5 / 23 CX-5 --
There are 2 side strips to pull off on left & right side of HU. Then you'll need 4 ford key remover tools. 2 go in each side to depress the release ears on the HU to pull it out of dash. 4 wire coathanger pieces shaped like a u can be used as well. Anyway, pull it straight out taking care to keep keys depressed so ears don't scratch radio surround on the way out & on the way back in when done. Undo the antenna & harness & your done. Next there are a couple of red screws that hold the CD module to top of HU. Remove them & module unplugs right out of the HU. The 6 changer goes in same place, screw back in & pop new face cover in place with load button on it. Put back in dash. Good to go.
