FS: 1993 Mazda Miata - $2700 OBO
Status
Not open for further replies.
Mikelly
Up for sale is a 1993 Mazda Miata in excellent condition. We bought the car from the original owner last spring and are selling it only to finance the build of another Miata into a SpecRacer. This car has been well cared for... and has about 205K miles on it.
Here's the list with the following maintenance history:
MILES LOF REPAIR COST
123 Paint Sealant $0.00
Install Alarm $0.00
Undercoating $0.00
Rustproof $0.00
Fabric Protect $0.00
602 X $52.24
1964 Antenna Repair $56.90
Top Latches $0.00
4023 X $47.58
7305 X $47.58
10166 X $47.53
12946 X Air Filter $268.81
Alignment $0.00
$520.64
15714 Body Work-R Bumper $297.37
16083 X $47.58
16570 New Battery $62.68
17800 Body Work-Hood $203.20
19591 X $47.66
23453 X $47.66
27393 X $47.66
29374 X 30,000 Mile check-up $416.93
32786 X $30.90
36751 X A/C Service $83.69
37857 Spark Plug Wires $144.09
Fuel and Air Induction
Service (Fuel Injec)
39700 Tires (4) $513.99
40216 X Cooling System Svc
Inspections/Emmiss $93.97
Battery $134.18
45690 X Front Brakes $41.65
50033 Oil and Filter
52422 Cooling System Svc $39.95
52422 Seat Belt Light Rpr $0.00
52422 Replace Pwr Ant $50.00
53570 Replace Rear Window $203.77
56977 Air Filter $12.00
57505 Oil and Filter $13.00
62200 Oil and Filter $13.00
66343 Oil and Filter $13.00
66363 Shocks (4)
Alignment, 4 wheel $392.38
66531 Rpr cooling fan $162.50
71761 Oil and Filter
Head Gasket
Antifreeze $907.57
75704 Oil and Filter $13.00
80585 Oil and Filter, Air Filter $13.00
84316 Oil and Filter, Air Filter $13.00
85796 Spark Plugs $12.00
87585 Lube, Oil, Filter $69.06
Transmission fluid
Differential fluid
87967 Timing belt $508.25
Fuel filter
A/C check
Roof tighten
Spark plug wires
90946 Air Filter $16.00
91244 Oil and Filter $13.00
93615 New Tires $388.78
95150 01/27/01 New Battery $108.10
95214 Lube, Oil, Filter
Check charging system $100.22
96245 02/27/01 Body Work $303.00
99115 07/08/01 Oil and Filter $13.00
103599 12/02/01 Oil and Filter $13.00
Wiper Blades
Air Filter $12.00
103962 12/07/01 Repair P/W switch $266.89
Rotate Tires
Flush and Fill
108833 03/30/02 Oil and Filter $13.00
Spark Plugs $12.00
Spark Plug wires $59.00
109146 04/07/02 PCV Valve $3.00
112713 06/29/02 Oil and Filter $13.00
10/01/02 Door Speakers $104.49
117568 10/14/02 Oil and Filter $13.00
120352 12/19/02 Front/Rear Struts
Front Brakes
R/F Lwr Ball Joint
Alignment
Flush Brake Fluid
Safety and Emmissions $1,461.54
120528 12/31/02 Air Filter $4.00
120528 12/31/02 Headrest Speakers $104.48
01/09/03 New Top $625.95
122724 02/23/03 Oil and Filter $13.00
123832 03/16/03 Valve cover gasket
Spark Plugs $66.00
124050 03/21/03 Spark Plug wires $39.99
127527 06/06/03 Upper Radiator Hose $10.00
Belts $23.00
127734 06/13/03 Radiator $153.26
Lower hoses $25.00
New Antifreeze $7.00
132720 09/24/03 LOF $774.17
Fuel Filter
Trans Fluid
Rear Diff Fluid
Clutch Fluid
Plugs
Valve Cover Gasket
Engine Flush
Air/Fuel Induction Svc
132835 09/27/03 New Antenna Mast $38.28
132850 09/28/03 Air Filter
133652 10/11/03 O2 sensor $30.00
Coolant temp sensor $30.00
new heater hoses (2) $39.46
133780 10/13/03 Cooling fan switch $80.52
134072 10/18/03 Fuel injection gasket $3.51
135462 11/13/03 Body Work $500.00
11/13/03 Alignment
136099 12/18/03 Tires (4) $281.96
136317 12/30/03 Clutch replacement $1,162.19
Timing belt
Thermostat
Water Pump
Valve Cover Gasket
Front engine seal
A/C P/S belt
137942 02/14/04 Oil and Filter $13.00
139950 03/31/04 Idle Speed Control Valve $552.50
140211 04/06/04 Tire Patch $28.20
Rotate Tires
142367 05/23/04 Oil and Filter $13.00
Air Filter $7.00
145204 08/07/04 Spark Plugs $12.50
145843 08/30/04 Spark Plug Wires $44.92
146238 09/09/04 Oil and Filter $26.93
Adjust idle
146716 09/18/04 Clutch Master and Slave Cylinders $278.18
Replace Radio $47.48
Replace Top $0.00
147625 10/04/04 Repair Driver's Seat $198.38
148936 12/03/04 Rear Bumper Replacement $0.00
148936 12/03/04 Tire Inspection, rot, bal, inspet alignment $0.00
149947 01/07/05 New Windshield $245.15
152056 03/04/05 Oil and Filter $28.55
152097 03/05/05 Pwr windor switch/Drv's side weatherstripping $84.15
152497 03/12/05 Upper and lower shift boots $43.66
153136 04/01/05 Compression test $110.00
(1: 180; 2:175; 3: 170; 4: 170)
153957 04/13/05 Plugs, Wires, PCV valve $59.10
155650 05/27/05 Top repairs (replace rain rail)+misc trim $385.68
155752 05/30/05 Oil and Filter $15.00
155756 06/04/05 Rear Bumper Repair/Repaint
Replace bumper reinforcement $0.00
156240 06/13/05 Rpl Cat Converter $246.05
156240 06/13/05 Rpl L/F Lower ball joint $206.92
156538 06/18/05 Air Filter $12.00
156810 06/26/05 CAS O'ring replacement $6.00
157089 07/03/05 Valve Cover Gasket Replacement $25.00
157141 07/06/05 A/C check
Cat Converter Gasket $227.02
157536 07/15/05 Fuel Filter $42.30
159644 09/10/05 Oil and Filter $66.63
Rotate Tires
Techron Gas Treatment
160292 09/30/05 Rear Struts $518.18
163806 01/15/06 Oil and Filter $20.00
164866 02/13/06 Drivers Mirror $153.30
166800 04/07/06 Front Brake Pads
Front Rotors
Lube calibers
Bleed and Flush brake lines $379.64
167663 05/15/06 Air Filter $15.00
168265 05/21/06 Oil and Filter $20.00
168732 06/02/06 2 new tires (rear)
Rotate Tires $224.98
168821 06/05/06 R-134 conversion $258.89
170863 08/06/06 Plugs and Wires $43.12
172067 09/07/06 Rear Brake Pads $557.30
Rear Brake Rotors
Rlr Right Rear Caliper
172472 09/17/06 Oil and Filter $25.00
175927 12/31/06 Oil and Filter $30.00
Air Filter $15.00
PCV Valve $3.00
178097 03/11/07 Driver's side window regulator $94.45
Replace Latch spring $1.00
179572 04/14/07 Rpr Window chips (2) $74.95
179936 04/21/07 Replace Under Cover $50.00
180500 05/08/07 New Radio $150.00
182349 07/04/07 Plugs and Wires $45.00
185186 09/23/07 Oil and Filter, Air Filter $50.00
185609 10/04/07 Upper and Lower shift boots and bushings $69.09
187917 12/08/07 Battery $123.51
188885 01/12/08 Flush and Fill
Adjust caliper piston $196.70
190051 02/10/08 Oil and Filter $30.00
190323 02/18/08 Tire rpr (R/F) $23.09
193968 05/24/08 Oil and Filter $30.00
197050 09/14/08 Oil and Filter $30.00
197607 09/28/08 Plugs and Wires
PCV Valve $75.78
A/C P/S belt
Alt W/P belt
Air Filter
198095 10/17/08 Loosen E brake $63.00
Reroute A/C drain hose
198112 10/18/08 2 new tires (front)
Alignment, 4 wheel $276.63
200463 01/10/09 Replace Driver's side turn signal $75.55
200463 01/10/09 Replace Pass side front marker gasket $7.30
200496 01/11/09 Replace Pass side turn signal $75.55
200496 01/11/09 Replace Driver's side front marker gasket $7.30
200686 01/20/09 Oil and Filter $30.00
200702 01/22/09 Rotate Tires
Fuel Filter
Transmission fluid
Differential fluid $248.42
200713 01/24/09 New Headlights (2) $45.90
200750 02/01/09 Replace washer nozzels $29.90
200750 02/01/09 Replace dipstick $10.95
200800 03/07/09 Replace Front weatherstripping $167.95
201257 05/08/09 Air Bag System Replacement $522.01
Install Alarm $0.00
Undercoating $0.00
Rustproof $0.00
602 X $52.24
Top Latches $0.00
4023 X $47.58
7305 X $47.58
10166 X $47.53
Alignment $0.00
$520.64
16083 X $47.58
19591 X $47.66
23453 X $47.66
27393 X $47.66
32786 X $30.90
Battery $134.18
66363 Shocks (4)
Head Gasket
Antifreeze $907.57
Transmission fluid
Differential fluid
Fuel filter
A/C check
Roof tighten
Spark plug wires
Wiper Blades
Air Filter $12.00
Rotate Tires
Flush and Fill
Spark Plugs $12.00
Front Brakes
R/F Lwr Ball Joint
Alignment
Flush Brake Fluid
Spark Plugs $66.00
Belts $23.00
Lower hoses $25.00
Fuel Filter
Trans Fluid
Rear Diff Fluid
Clutch Fluid
Plugs
Valve Cover Gasket
Engine Flush
11/13/03 Alignment
Timing belt
Thermostat
Water Pump
Valve Cover Gasket
Front engine seal
A/C P/S belt
Rotate Tires
Air Filter $7.00
Adjust idle
Replace Top $0.00
Rotate Tires
Front Rotors
Lube calibers
Rear Brake Rotors
Air Filter $15.00
PCV Valve $3.00
PCV Valve $75.78
A/C P/S belt
Alt W/P belt
Air Filter
Fuel Filter
Transmission fluid
TOTAL $20,537.50
Some random pics of the car with top up and down:
That's what was done to the car up until when we bought it... It has a new convertible top on it, and comes with the following extras:
Pictured with the bronze 15X6.5 racing wheels on it. Exceptionally light and strong at 12# each.
Extra set of stockers with like new tires.
Rear deck pedistal mount spoiler in gelcoat white, will need paint (as seen on our white car)
Harddog rollbar (As seen on otheir site).
http://bethania-garage.com/hardcore.htm
We're asking $2700 or best offer. We're looking to move this car, as it is taking up shop space at this point and the funds will be going straight to Mitch Piper for the cost of the cage he's welding into the other Miata this coming week.
Car also has the front lip spoiler painted in black...
Contact me at [email removed]
We're going to need to see photos w/signage in compliance with the rules (see the link in my signature.)
Until those are available, this thread will need to be locked. Please send a PM to me or any of the section mods to request this thread be unlocked when you're ready to upload the proper pics.
Please also add your location to your profile.
Thanks (2thumbs)
Another note: I believe you have duplicate information in your description, perhaps you copy-pasted too many times.
Status
